155
Add new row into WebDataGrid using Javascript deleteing the first row
I have a strange issue, I have a bottom that adds a new records into WebDataGrid using Java script, the issue that after I add the first new row, and trying to add second row it deletes the first row , after that it works fin, only with the first row at the first time! also the counting starts with 0, so when i insert the row, it would give me 0 under No. and then when I add a new row it deletes the 0 row and add the 1 No, and it goes normally, can you please help?
 function AddDocCheckList() {
            var grid = $find('<%= chdocs_web.ClientID %>');
            var rowscount = grid.get_rows().get_length() +1  ;
            var doctype = $find('<%= chdoctype_drop.ClientID %>');
            var chyes = $find('<%= chyes_drop.ClientID %>');
            var chComments = $find('<%= chcomments_txt.ClientID %>');
            var rows = grid.get_rows();
            var rr = new Array(rowscount, doctype.get_selectedItem().get_value(), chyes.get_selectedItem().get_value(), chComments.get_value())
            grid.get_rows().add(rr);
<igtxt:WebImageButton ID="checkinsert_btn" runat="server" Text="Insert Document" AutoSubmit="false">
<ClientSideEvents Click="AddDocCheckList" />
<Appearance>
<Image Url="./Res/Apps-Dialog-Add-icon.png" />
</Appearance>
</igtxt:WebImageButton>
 <ig:WebDataGrid ID="chdocs_web" runat="server" AutoGenerateColumns="False" DataSourceID="ComDocchecklistDS" Height="350px" Width="561px" EnableAjax="False">
                                    <Columns>
                                        <ig:BoundDataField DataFieldName="orderno" Key="orderno" Width="35px">
                                            <Header Text="No.">
                                            </Header>
                                        </ig:BoundDataField>
                                        <ig:BoundDataField DataFieldName="doctype" Key="doctype">
                                            <Header Text="Document Received">
                                            </Header>
                                        <ig:BoundDataField DataFieldName="yesno" Key="yesno" Width="60px">
                                            <Header Text="Yes/No">
                                            </Header>
                                        <ig:BoundDataField DataFieldName="comments" Key="comments">
                                            <Header Text="Comments">
                                            </Header>
                                    </Columns>
                                    <Behaviors>
                                        <ig:EditingCore BatchUpdating="True">
                                        </ig:EditingCore>
                                    </Behaviors>
                                </ig:WebDataGrid>
<Appearance>
</Appearance>
First attempt to insert a row
second attempt and afterwards, you can see it deleted the 0 No which was inserted in the first attempt
