125
WHDG throws async error: Update/Insert Procedure or function as too many arguments specified.
I'm experiencing some issues with the WHDG. I have seen similar post on this issue but none seems to address the problem I'm having. I am using version 2019.1 CLR45. I know this error normally occurs when a parameter is misspelled or missing but that's not the case here. I'm also having difficulties getting the key values from the parent row to assign to the child row for inserting and updating. Code snippets below:
Thank you in advance for any help on this issue.
Markup:
<body>
    <form id="form1" runat="server">
        <ig:WebScriptManager ID="WebScriptManager1" runat="server" EnablePageMethods="True" ValidateRequestMode="Enabled"></ig:WebScriptManager>
        <igmisc:WebPageStyler ID="WebPageStyler1" runat="server" EnableAppStyling="True" StyleSetName="Default" />
       <asp:HiddenField ID="hdnUserName" runat="server" />
     <asp:HiddenField ID="hdnFacilityID" runat="server" />
     <asp:HiddenField ID="hdnFacilityName" runat="server" />
      <asp:SqlDataSource ID="dsFacilityParent" runat="server" ConnectionString="<%$ ConnectionStrings:CHPComplianceDB %>" SelectCommand="usp_get_Facility_License_Parent" SelectCommandType="StoredProcedure"></asp:SqlDataSource>
      <asp:SqlDataSource ID="dsFaciltyChild" runat="server" ConnectionString="<%$ ConnectionStrings:CHPComplianceDB %>" InsertCommand="usp_ins_tbl_Facility_License" InsertCommandType="StoredProcedure" SelectCommand="usp_get_Facility_License_Child" SelectCommandType="StoredProcedure" UpdateCommand="usp_upd_tbl_Facility_License" UpdateCommandType="StoredProcedure">
          <InsertParameters>
              <asp:Parameter Name="Facility_ID" Type="Int32" />
              <asp:Parameter Name="Facility_Name" Type="String" />
              <asp:Parameter Name="Facility_License_Type" Type="String" />
              <asp:Parameter Name="Entity_Code" Type="String" />
              <asp:Parameter Name="Facility_License_Nbr" Type="String" />
              <asp:Parameter Name="License_Issue_Date" Type="String"/>
              <asp:Parameter Name="License_Expire_Date" Type="String" />
              <asp:Parameter Name="Owner" Type="String" />
              <asp:Parameter Name="Co_Owner" Type="String" />
              <asp:Parameter Name="Comment" Type="String" />
              <asp:Parameter Name="Inserted_by" Type="String" />
              <asp:Parameter Name="Inesert_Time" Type="DateTime" />
              <asp:Parameter Name="Updated_by" Type="String" />
              <asp:Parameter Name="Update_Time" Type="DateTime" />
          </InsertParameters>
          <UpdateParameters>
              <asp:Parameter Name="Facility_License_ID" Type="Int32" />
          </UpdateParameters>
     <asp:SqlDataSource ID="dsListLicenseType" runat="server" ConnectionString="<%$ ConnectionStrings:CHPComplianceDB %>" SelectCommand="SELECT Facility_License_Type_ID
       ,Facility_License_Type_Name
FROM dbo.tbl_Faciliy_License_Type
ORDER BY Facility_License_Type_ID"></asp:SqlDataSource>
    <asp:SqlDataSource ID="dsListEntityCode" runat="server" ConnectionString="<%$ ConnectionStrings:CHPComplianceDB %>" SelectCommand="SELECT Licensing_Entity_ID, Entity_Code
FROM dbo.tbl_Licensing_Entity
ORDER BY Licensing_Entity_ID"></asp:SqlDataSource>
    <asp:SqlDataSource ID="dsOwverEmployee" runat="server" ConnectionString="<%$ ConnectionStrings:CHPComplianceDB %>" SelectCommand="SELECT DISTINCT Employee_ID = ADS_Person_ID, Employee_Name = Display_Name
FROM dbo.tbl_ADS_Person
WHERE Is_Active = 1 AND Department_Name &lt;&gt; ''
ORDER BY Display_Name"></asp:SqlDataSource>
    <ig:WebHierarchicalDataSource ID="WebHierarchicalDataSource1" runat="server">
        <DataViews>
            <ig:DataView ID="dsFacilityParent_DefaultView" DataMember="DefaultView" DataSourceID="dsFacilityParent" />
            <ig:DataView ID="dsFaciltyChild_DefaultView" DataMember="DefaultView" DataSourceID="dsFaciltyChild" />
        </DataViews>
        <DataRelations>
            <ig:DataRelation ChildColumns="Facility_ID,Facility_Name" ChildDataViewID="dsFaciltyChild_DefaultView" ParentColumns="Facility_ID,Facility_Name" ParentDataViewID="dsFacilityParent_DefaultView" />
        </DataRelations>
      </ig:WebHierarchicalDataSource>
    <div class="w3-panel w3-light-grey">
        <div class="w3-container w3-teal w3-center w3-margin-bottom w3-margin-top w3-card-4">
            <h4><b><i class="fa fa-building"></i> Facility Licensing</b></h4>
        </div>
        <div class="w3-container w3-white w3-card-4 w3-round-large w3-margin">
            <div class="w3-row-padding w3-center w3-margin">
                <div class="w3-col" style="width: 20%">
                    <button id="btnFacility" class="w3-btn w3-teal"><i class="fa fa-building-o"></i> Manage Facilties</button>
                </div>
                    <button id="btnLicType" class="w3-btn w3-teal"><i class="fa fa-id-card"></i> Manage License Types</button>
                </div>
                <div class="w3-rest" style="width: 20%">
                    <button id="bntEntity" class="w3-btn w3-teal"><i class="fa fa-id-card-o"></i> Manage Entities</button>
                </div>
            </div>
        </div>
            <center class="w3-margin">
            <ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid1" runat="server" Width="96%" AutoGenerateBands="False" AutoGenerateColumns="False" DataKeyFields="Facility_ID,Facility_Name" DataMember="dsFacilityParent_DefaultView" DataSourceID="WebHierarchicalDataSource1" Key="dsFacilityParent_DefaultView"  CssClass="GridHeader GridMinHeight" ItemCssClass="GridHeader" HeaderCaptionCssClass="w3-teal">
                <Bands>
                    <ig:Band AutoGenerateColumns="False" DataMember="dsFaciltyChild_DefaultView" Key="dsFaciltyChild_DefaultView" DataKeyFields="Facility_License_ID">
                        <Columns>
                            <ig:BoundDataField DataFieldName="Facility_License_ID" Hidden="True" Key="Facility_License_ID">
                                <Header Text="Facility_License_ID">
                                </Header>
                            </ig:BoundDataField>
                            <ig:BoundDataField DataFieldName="Facility_ID" Hidden="True" Key="Facility_ID">
                                <Header Text="Facility_ID">
                                </Header>
                            <ig:BoundDataField DataFieldName="Facility_Name" Key="Facility_Name" Hidden="True">
                                <Header Text="Facility_Name">
                                </Header>
                            <ig:BoundDataField DataFieldName="Facility_License_Type" Key="Facility_License_Type">
                                <Header Text="License Type">
                                </Header>
                            <ig:BoundDataField DataFieldName="Entity_Code" Key="Entity_Code">
                                <Header Text="Licensing Entity">
                                </Header>
                            <ig:BoundDataField DataFieldName="Facility_License_Nbr" Key="Facility_License_Nbr">
                                <Header Text="License Nbr">
                                </Header>
                            <ig:BoundDataField DataFieldName="License_Issue_Date" Key="License_Issue_Date" DataFormatString="{0:d}">
                                <Header Text="Issue Date">
                                </Header>
                            <ig:BoundDataField DataFieldName="License_Expire_Date" Key="License_Expire_Date" DataFormatString="{0:d}">
                                <Header Text="Expire Date">
                                </Header>
                            <ig:BoundDataField DataFieldName="Owner" Key="Owner">
                                <Header Text="Owner">
                                </Header>
                            <ig:BoundDataField DataFieldName="Co_Owner" Key="Co_Owner">
                                <Header Text="Co Owner">
                                </Header>
                            <ig:BoundDataField DataFieldName="Comment" Key="Comment">
                                <Header Text="Comments">
                                </Header>
                            <ig:BoundDataField DataFieldName="Inserted_by" Key="Inserted_by">
                                <Header Text="Created By">
                                </Header>
                            <ig:BoundDataField DataFieldName="Inesert_Time" Key="Inesert_Time" DataFormatString="{0:d} {0:t}">
                                <Header Text="Create Time">
                                </Header>
                            <ig:BoundDataField DataFieldName="Updated_by" Hidden="True" Key="Updated_by">
                                <Header Text="Updated_by">
                                </Header>
                            <ig:BoundDataField DataFieldName="Update_Time" Hidden="True" Key="Update_Time">
                                <Header Text="Update_Time">
                                </Header>
                        </Columns>
                        <Behaviors>
                            <ig:EditingCore EnableInheritance="True">
                                <Behaviors>
                                    <ig:CellEditing>
                                        <ColumnSettings>
                                            <ig:EditingColumnSetting ColumnKey="Facility_License_Type" EditorID="WebHierarchicalDataGrid1_DropDownProvider1" />
                                            <ig:EditingColumnSetting ColumnKey="Entity_Code" EditorID="WebHierarchicalDataGrid1_DropDownProvider2" />
                                            <ig:EditingColumnSetting ColumnKey="License_Issue_Date" EditorID="WebHierarchicalDataGrid1_DatePickerProvider1" />
                                            <ig:EditingColumnSetting ColumnKey="License_Expire_Date" EditorID="WebHierarchicalDataGrid1_DatePickerProvider2" />
                                            <ig:EditingColumnSetting ColumnKey="Owner" EditorID="WebHierarchicalDataGrid1_DropDownProvider3" />
                                            <ig:EditingColumnSetting ColumnKey="Co_Owner" EditorID="WebHierarchicalDataGrid1_DropDownProvider4" />
                                            <ig:EditingColumnSetting ColumnKey="Comment" EditorID="WebHierarchicalDataGrid1_TextEditorProvider1" />
                                            <ig:EditingColumnSetting ColumnKey="Inserted_by" ReadOnly="True" />
                                            <ig:EditingColumnSetting ColumnKey="Inesert_Time" ReadOnly="True" />
                                            <ig:EditingColumnSetting ColumnKey="Updated_by" ReadOnly="True" />
                                            <ig:EditingColumnSetting ColumnKey="Update_Time" ReadOnly="True" />
                                        </ColumnSettings>
                                    </ig:CellEditing>
                                    <ig:RowEditing>
                                        <ColumnSettings>
                                        </ColumnSettings>
                                    </ig:RowEditing>
                                    <ig:RowAdding>
                                        <ColumnSettings>
                                            <ig:RowAddingColumnSetting ColumnKey="Facility_License_Type" EditorID="WebHierarchicalDataGrid1_DropDownProvider1" />
                                            <ig:RowAddingColumnSetting ColumnKey="Entity_Code" EditorID="WebHierarchicalDataGrid1_DropDownProvider2" />
                                            <ig:RowAddingColumnSetting ColumnKey="License_Issue_Date" EditorID="WebHierarchicalDataGrid1_DatePickerProvider1" />
                                            <ig:RowAddingColumnSetting ColumnKey="License_Expire_Date" EditorID="WebHierarchicalDataGrid1_DatePickerProvider2" />
                                            <ig:RowAddingColumnSetting ColumnKey="Owner" EditorID="WebHierarchicalDataGrid1_DropDownProvider3" />
                                            <ig:RowAddingColumnSetting ColumnKey="Co_Owner" EditorID="WebHierarchicalDataGrid1_DropDownProvider4" />
                                            <ig:RowAddingColumnSetting ColumnKey="Inserted_by" ReadOnly="True" />
                                            <ig:RowAddingColumnSetting ColumnKey="Inesert_Time" ReadOnly="True" />
                                        </ColumnSettings>
                                    </ig:RowAdding>
                                </Behaviors>
                            </ig:EditingCore>
                            <ig:RowSelectors>
                            </ig:RowSelectors>
                        </Behaviors>
                    </ig:Band>
                </Bands>
                <EditorProviders>
                    <ig:DropDownProvider ID="WebHierarchicalDataGrid1_DropDownProvider1">
                        <EditorControl ClientIDMode="Predictable" DataSourceID="dsListLicenseType" DropDownContainerMaxHeight="200px" EnableAnimations="False" EnableDropDownAsChild="False" TextField="Facility_License_Type_Name" ValueField="Facility_License_Type_Name" runat="server">
                            <DropDownItemBinding TextField="Facility_License_Type_Name" ValueField="Facility_License_Type_Name" />
                        </EditorControl>
                    </ig:DropDownProvider>
                    <ig:DropDownProvider ID="WebHierarchicalDataGrid1_DropDownProvider2">
                        <EditorControl ClientIDMode="Predictable" DataSourceID="dsListEntityCode" DropDownContainerMaxHeight="200px" EnableAnimations="False" EnableDropDownAsChild="False" TextField="Entity_Code" ValueField="Entity_Code" runat="server">
                            <DropDownItemBinding TextField="Entity_Code" ValueField="Entity_Code" />
                        </EditorControl>
                    <ig:DropDownProvider ID="WebHierarchicalDataGrid1_DropDownProvider3">
                        <EditorControl ClientIDMode="Predictable" DataSourceID="dsOwverEmployee" DropDownContainerMaxHeight="200px" EnableAnimations="False" EnableDropDownAsChild="False" TextField="Employee_Name" ValueField="Employee_Name" runat="server">
                            <DropDownItemBinding TextField="Employee_Name" ValueField="Employee_Name" />
                        </EditorControl>
                    <ig:DatePickerProvider ID="WebHierarchicalDataGrid1_DatePickerProvider1">
                        <EditorControl ClientIDMode="Predictable" runat="server">
                        </EditorControl>
                    </ig:DatePickerProvider>
                    <ig:TextEditorProvider ID="WebHierarchicalDataGrid1_TextEditorProvider1">
                        <EditorControl ClientIDMode="Predictable" TextMode="MultiLine" runat="server">
                        </EditorControl>
                    </ig:TextEditorProvider>
                    <ig:DatePickerProvider ID="WebHierarchicalDataGrid1_DatePickerProvider2">
                        </EditorControl>
                    <ig:DropDownProvider ID="WebHierarchicalDataGrid1_DropDownProvider4">
                        </EditorControl>
                </EditorProviders>
                <Columns>
                        </Header>
                    <ig:BoundDataField DataFieldName="Facility_Name" Key="Facility_Name">
                        <Header Text="Facility">
                        </Header>
                </Columns>
            </ig:WebHierarchicalDataGrid>
            </center>
        </div>
    </div>
    </form>
</body>
Code Behind:
Imports System.Data
Imports System.Data.SqlClient
Imports System.Web.HttpContext
Imports Infragistics.Web.UI.GridControls
Imports System.Net.Mail
Imports Infragistics.Web.UI.WebScriptManager
Imports System.Web.Services
Partial Class _Default
    Inherits System.Web.UI.Page
    'Private struserID As String = Right(Current.User.Identity.Name, Current.User.Identity.Name.Length - 4)
    Private strFID As String = ""
    Private strFname As String = ""
    Private ParentIndex As Integer
    Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        Dim strUserName As String = "Forrest A. Gump"  ''GetUserName(struserID)
        hdnUserName.Value = strUserName
    End Sub
    Private Sub dsFaciltyChild_Inserting(sender As Object, e As SqlDataSourceCommandEventArgs) Handles dsFaciltyChild.Inserting
        If IsDate(e.Command.Parameters.Item("@License_Issue_Date").Value) Then
            e.Command.Parameters.Item("@License_Issue_Date").Value = FormatDateTime(e.Command.Parameters.Item("@License_Issue_Date").Value, DateFormat.ShortDate)
        End If
        If IsDate(e.Command.Parameters.Item("@License_Expire_Date").Value) Then
            e.Command.Parameters.Item("@License_Expire_Date").Value = FormatDateTime(e.Command.Parameters.Item("@License_Expire_Date").Value, DateFormat.ShortDate)
        End If
        e.Command.Parameters.Item("@Facility_ID").Value = CInt(hdnFacilityID.Value)
        e.Command.Parameters.Item("@Facility_Name").Value = hdnFacilityName.Value
        e.Command.Parameters.Item("@Inserted_by").Value = hdnUserName.Value
        e.Command.Parameters.Item("@Inesert_Time").Value = FormatDateTime(Now, DateFormat.GeneralDate)
        e.Command.Parameters.Item("@Updated_by").Value = hdnUserName.Value
        e.Command.Parameters.Item("@Update_Time").Value = FormatDateTime(Now, DateFormat.GeneralDate)
    End Sub
    Private Sub dsFaciltyChild_Updating(sender As Object, e As SqlDataSourceCommandEventArgs) Handles dsFaciltyChild.Updating
        End If
        End If
    End Sub
    Private Sub WebHierarchicalDataGrid1_RowIslandDataBound(sender As Object, e As RowIslandEventArgs) Handles WebHierarchicalDataGrid1.RowIslandDataBound
        Dim strRwsIsLand As String = e.RowIsland.ID
        If e.RowIsland.DataMember = "dsFaciltyChild_DefaultView" Then
            If Not IsNothing(e.RowIsland.ParentRow) Then
                If Not IsNothing(e.RowIsland.ParentRow.Items(0).Value) Then
                    hdnFacilityID.Value = e.RowIsland.ParentRow.Items(0).Value.ToString
                    ParentIndex = e.RowIsland.ParentRow.Index
                    strFID = hdnFacilityID.Value
                    hdnFacilityName.Value = e.RowIsland.ParentRow.Items(1).Value.ToString
                    strFname = hdnFacilityName.Value
                End If
            End If
        ElseIf e.RowIsland.DataMember = "dsFacilityParent_DefaultView" Then
            If Not e.RowIsland.Rows Is Nothing Then
                If Not e.RowIsland.Rows(ParentIndex).Items Is Nothing Then
                    hdnFacilityID.Value = e.RowIsland.Rows(ParentIndex).Items(0).Value
                    hdnFacilityName.Value = e.RowIsland.Rows(ParentIndex).Items(1).Value
                End If
            End If
        End If
    End Sub
    Private Sub WebHierarchicalDataGrid1_RowExpanded(sender As Object, e As ContainerRowEventArgs) Handles WebHierarchicalDataGrid1.RowExpanded
        If e.Row.DataItem.[Type] = "dsFacilityParent_DefaultView" Then
            ParentIndex = e.Row.Index
        End If
    End Sub
    Public Shared Function GetUserName(ByVal StremployeeID As String) As String
        If StremployeeID.Length > 0 Then
            Dim strCnn As String = ConfigurationManager.ConnectionStrings.Item("CHPComplianceDB").ToString
            Dim strSQL As String = "SELECT Top 1 Display_Name FROM dbo.tbl_ADS_Person WHERE ADS_Person_ID  = '" & StremployeeID & "'"
            Dim strUserName As String = ""
            Dim m_DBCn As New SqlConnection(strCnn)
            m_DBCn.Open()
            Dim drDep As SqlDataReader = GetDataReader(strSQL, 30, m_DBCn)
            If drDep.HasRows Then
                strUserName = drDep("Display_Name").ToString
                drDep.Close()
                m_DBCn.Close()
                Return strUserName
            Else
                Return ""
            End If
        Else
            Return ""
        End If
    End Function
    Public Shared Function GetDataReader(ByVal SQL As String, ByVal Timeout As Integer, ByVal Cn As SqlConnection, Optional ByVal blnSkipRead As Boolean = False) As SqlDataReader
        Dim cmdQuery As New SqlCommand
        Dim dr As SqlDataReader
        cmdQuery.Connection = Cn
        cmdQuery.CommandTimeout = Timeout
        cmdQuery.CommandText = SQL
        cmdQuery.CommandType = CommandType.Text
        dr = cmdQuery.ExecuteReader
        If Not blnSkipRead Then dr.Read()
        Return dr
    End Function
End Class
