140
Set CellText value with Infragistic checkBox from code behind in c#
 i am Implementing Web Hirarchical Data Grid and i have a checkBox , i want to set the Value of cell Text from Server side as each cell text can have different Value . Both Front end and BackEnd Code is :
<ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid1" runat="server" AutoGenerateBands="False"
AutoGenerateColumns="False" DataKeyFields="id" DataMember="Module" EnableViewState="true"
ViewStateMode="Enabled"
InitialExpandDepth="3" InitialDataBindDepth="3"
Height="350px" Width="900px" >
<%--<ClientEvents Initialize="InitializHandler" Click="ClickHandler"/>--%>
<%-- <AutoPostBackFlags RowSelectionChanged="false" />--%>
<%--<AutoPostBackFlags CellSelectionChanged="Of" />--%>
<Columns>
<ig:BoundDataField DataFieldName="id" Hidden="true" DataType="System.Int32" Key="id" Width="100px">
<Header Text="Module ID" />
</ig:BoundDataField>
<ig:BoundDataField DataFieldName="Item" DataType="System.String" Key="Item">
<Header Text="Module Description" />
<ig:BoundDataField DataFieldName="Data" Hidden="true" DataType="System.String" Key="Data">
<Header Text="Operations" />
<%--<ig:BoundCheckBoxField DataFieldName="View" DataType="System.Boolean" Key="View">
<Header Text="View" />
</ig:BoundCheckBoxField>
<ig:BoundCheckBoxField DataFieldName="Update" DataType="System.Boolean" Key="Update">
<Header Text="Update" />
<ig:BoundCheckBoxField DataFieldName="Delete" DataType="System.Boolean" Key="Delete">
<Header Text="Delete" />
<ig:BoundCheckBoxField DataFieldName="Save" DataType="System.Boolean" Key="Save">
<Header Text="Save" />
</ig:BoundCheckBoxField>--%>
</Columns>
<Bands>
<ig:Band AutoGenerateColumns="False" DataKeyFields="Item" DataMember="TRN_CODE" Key="ChildBand_0">
<Columns>
<%-- <ig:BoundDataField DataFieldName="ChildTableId" Hidden="false" DataType="System.Int32" Key="ChildTableId">
<Header Text="ChildTableId" />
</ig:BoundDataField>--%>
<ig:BoundDataField DataFieldName="ChildId" Hidden="true" DataType="System.Int32" Key="DataCh">
<Header Text="Child Id" />
<ig:BoundDataField DataFieldName="Item" DataType="System.String" Key="ItemCh">
<Header Text="Child Item" />
<ig:BoundDataField DataFieldName="ParentId" Hidden="true" DataType="System.Int32" Key="idCh">
<Header Text="Parent ID" />
<%--<ig:BoundDataField DataFieldName="Operations" Hidden="false" DataType="System.String" Key="Operations">
<ig:BoundCheckBoxField DataFieldName="Operations" Key="Operations" CellText="WanttoGetValuefromServer">
<%--<ig:BoundCheckBoxField DataFieldName="ChView" DataType="System.Boolean" Key="ChView">
<ig:BoundCheckBoxField DataFieldName="ChUpdate" DataType="System.Boolean" Key="ChUpdate">
<ig:BoundCheckBoxField DataFieldName="ChDelete" DataType="System.Boolean" Key="ChDelete">
<ig:BoundCheckBoxField DataFieldName="ChSave" DataType="System.Boolean" Key="ChSave">
</Columns>
<Behaviors>
<ig:EditingCore BatchUpdating="True">
<Behaviors>
<ig:RowAdding/>
<ig:RowDeleting/>
<ig:CellEditing/>
</Behaviors>
</ig:EditingCore>
<%--<ig:EditingCore AutoCRUD="false">
<Behaviors>
<ig:CellEditing>
<ColumnSettings>
<ig:EditingColumnSetting ColumnKey="ItemCh" ReadOnly="true" />
</ColumnSettings>
</ig:CellEditing>
</Behaviors>
</ig:EditingCore>--%>
</Behaviors>
</ig:Band>
</Bands>
<Behaviors>
<ig:Selection CellClickAction="Row" CellSelectType="None" RowSelectType="Single">
<AutoPostBackFlags CellSelectionChanged="false" RowSelectionChanged="false" ColumnSelectionChanged="false" />
<%--<AutoPostBackFlags RowSelectionChanged="false" />--%>
</ig:Selection>
<ig:Activation>
</ig:Activation>
<ig:EditingCore BatchUpdating="True"/>
<%--<ig:EditingCore>
<Behaviors>
<ig:CellEditing>
<ColumnSettings>
<ig:EditingColumnSetting ColumnKey="Item" ReadOnly="true" />
</ColumnSettings>
</ig:CellEditing>
</Behaviors>
</Behaviors>
</ig:WebHierarchicalDataGrid>
