I have a Datatable that I attach as a datasource to a Webdatagrid. The Datatable has dynamically chosen columns with dynamically chosen order. As such I never know which columns will be selected and in which order they will be. I do know the Column headers and would like to format the columns that have currency in their fields to have a $ in front of them and 2 decimals after them. I'm not able to figure out how to do this.
For example:
WebDataGrid1.DataSource = dt
For Each col In WebDataGrid1.Columns If col.Caption = "Total" Then
End If Next
I can see
WebDataGrid1.Columns(0).FormatFieldMethod = New FormatRecordItemValue()
But iterating through webdatagrid1 I can't find col.FormatFieldMethod
I can also not find what to pass to FormatRecordItemValue as it constantly tells me I'm entering the wrong value. I tried following the example in
https://es.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/19758/set-dataformatstring-in-server-side-code-for-a-specific-cell
In c#, the string Format method is used to insert the value of variable or an object or expression into another string. By using string Format method, we can replace the format items in the specified string with the string representation of specified objects.
www.gangboard.com/.../selenium-training
www.gangboard.com/.../core-java-training
well! Thanks for providing a good stuff related to DevOps Explination is good, nice Articleanyone want to learn advance devops tools or devops online training
Answering my own question:,To dynamically format autogenerated field, use this:
DirectCast(column, AutoGeneratedDataField).DataFormatString = "{0:P}"
Datastring can be easily understandable if u know about .NET and you yourself can solve easily
Hi Denis,
I am also having this problem.
The link you provided results in 404 error, while the sample I downloaded does *not* show how to use FormatFieldMethod function.
Specifically all samples from Infragistics show how to return 'hello', but do not show how to properly pass values.
Could you please post a code sample of how to use FormatFieldMethod function.
Thank you,
Helen.
