All I have are X's (img placeholders) showing.
Here is the assembly/Verstion:
<%@ Register assembly="Infragistics4.Web.v13.1, Version=13.1.20131.2331, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.EditorControls" tagprefix="ig" %>
Here is the apsx page:
<ig:WebDatePicker ID="WebDatePicker2" runat="server" DisplayModeFormat="d" DropDownCalendarID="WebMonthCalendar2" StyleSetPath="~/images/Infragistics/" > </ig:WebDatePicker> <ig:WebMonthCalendar ID="WebMonthCalendar2" runat="server" StyleSetPath="~/images/Infragistics/" > </ig:WebMonthCalendar>
In my Web.config file I have this in the configuation section:
<infragistics.web enableAppStyling="true" styleSetPath="~/images/Infragistics/" />
Any idea why I can't get the DropDown image nor the Previous and Next arrow images to show?
Thanks.
Hello Kevin,
It was my pleasure to guide you.
If you have further questions, please feel free to contact us.
Best Regards,Aleksandar KamenovEntry-level Software DeveloperInfragistics, Inc.
DONE ! Many thanks !
Note 1: For some reason the way I add items to the application in VS 2015 affects if I can reference those style folders. They weren't appearing just dragging and dropping.
Note 2: I have our procurement guy checking on getting a more current version, but since I work in a Gov't agency, it could be awhile. He thinks we should already be paying for current versions, but since this is an old app dropped on us, I have to go with what I got.
having said that, I really appreciate you helping us through this. Many thanks for the time.
Kevin
Everything works great for me. You can see the attached sample I have ig_res folder in the app that specify current path. For example for the date picker there is StylePath that is:StyleSetPath="~/ig_res/Styles/" and StyleName that is: StyleSetName="Office2007Blue".You can see the ig_res directory representation.
In the second control WebMonthCalendar my ig_res folder is on IIS. My folder in the IIS contains only two directory Default and Office2007Blue. In the web config I'm setting the specific path to this folder like this: <infragistics.web styleSetName="Default" styleSetPath="http://localhost/ig_res"/>, and only that you need to do is to set StyleSetName to be Office2007Blue.
Please try this approach, and keep me posted if you need further assistance.
Okay, I have images ! I had read instruction that I needed a virtual directory in IIS and had to reference that. That is not the case. ig_res has to be in the application directory.
Follow up:
How can I use the Styles? I have added the Styles directory to the ig_res like I did the Default directory but can't get it to work with individual controls.
Did not work:
<ig:WebDatePicker ID="eddWebDatePicker1" runat="server" DisplayModeFormat="d" DropDownCalendarID="CalendarView" >
</ig:WebDatePicker> <ig:WebMonthCalendar runat="server" ID="CalendarView" EnableWeekNumbers="true" ChangeMonthToDateClicked="true" EnableMonthDropDown="True" EnableYearDropDown="True" StyleSetPath="~/ig_res" StyleSetName="Styles/Office2007Blue" > </ig:WebMonthCalendar>
nor
</ig:WebDatePicker> <ig:WebMonthCalendar runat="server" ID="CalendarView" EnableWeekNumbers="true" ChangeMonthToDateClicked="true" EnableMonthDropDown="True" EnableYearDropDown="True" StyleSetPath="~/ig_res/Styles" StyleSetName="Office2007Blue" > </ig:WebMonthCalendar>
THANKS for helping. We are checking on our licensing, but since I work for a Gov agency, it is taking a while.
Hey, Many thanks. that helped clear one issue I would have had later.
okay, so ~/ig_res is a vertal directory? It points to: C:\inetpub\wwwroot\aspnet_client\Infragistics with sub directory of Images and 20131CLR4. Images has some images and a few sub directores (arrow etc..) 20131CLR4 has sub directories for Forms, Scripts, Styles.
I don't see any 'Default' directory. Would the config setting need to change to something else?
I've copied the Default directory included in your example to C:\inetpub\wwwroot\aspnet_client\Infragistics but they didn't show the images either.
