I use the UltraWebGrid.ExcelExport to export the data in the UltraWebGrid. The generated excel file can be saved and view from client side. But the screen keeps freezing with the focus cannot change to normal and cannot select any other controls. Only way is close the IE.
Do you have some advice how to fix it? Thanks very much!
Following is part of code:
<%@ register="" assembly="Infragistics2.WebUI.UltraWebGrid.ExcelExport.v11.1, Version=11.1.20111.1006, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" br=""> namespace="Infragistics.WebUI.UltraWebGrid.ExcelExport" tagprefix="igtblexp" %>
runat="server">
protected void btnInfCheckExport_Click(object sender, EventArgs e) {
string fileName = "Data"; UltraWebGridExcelExporter1.DownloadName = fileName; UltraWebGridExcelExporter1.WorksheetName = "ShipDetailInfCheckResult";
UltraWebGridExcelExporter1.ExportMode = Infragistics.WebUI.UltraWebGrid.ExcelExport.ExportMode.InBrowser; UltraWebGridExcelExporter1.Export(ShipperDetailInfCheckUltraWebGrid);
Thank you for posting in Infragistics community !
The UltraWebGrid support has expired and this means we are not able to investigate this issue neither provide a fix if it turns out to be a bug in our code. I suggest that you upgrade your product to a supported version (latest is 15.2), which also includes migrating from the old UltraWebGrid to the WebDataGrid.
If you go for this do not hesitate to contact us for every struggles regarding the migrating and upgrading process, we will be glad to help !
