190
Server side Node Expanded Event needs 3 clicks to fire
I have a web application project with Infragistics 2014.2 and .net Framework 4. In my web page I put a WebDataTree that is loaded only the first level of nodes. I need to get server side events every time a node is clicked or the node's expand button is clicked in order to decide programmatically if the child nodes need to be loaded.
This scenario works fine but the user needs to click three times the expand button to fire the server side event. This happened only when the node has no children loaded. If a node has children loaded the expand events working fine.
I created a small example showing this issue.
Default.aspx
<%@ Page Language="vb" AutoEventWireup="false" CodeBehind="Default.aspx.vb" Inherits="WebDataTreeTest._Default" %>
<%@ Register Assembly="Infragistics4.Web.v14.2, Version=14.2.20142.2480, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.NavigationControls" TagPrefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title></title>
</head>
<body>
    <form id="form1" runat="server">
    <div>
        <asp:ScriptManager ID="ScriptManager1" runat="server"></asp:ScriptManager>
        <ig:WebDataTree ID="WebDataTree1" runat="server" Height="600" Width="400px"
            CheckBoxMode="BiState" NodeIndent="18" EnableAjaxViewState="true"
            OnNodeClick="WebDataTree1_NodeClick" OnNodeExpanded="WebDataTree1_NodeExpanded">
            <AutoPostBackFlags NodeClick="On" NodeExpanded="On" />
        </ig:WebDataTree>
    </div>
    </form>
</body>
</html>
Default.aspx.vb
Public Class _Default
    Inherits System.Web.UI.Page
    Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        If Not Page.IsPostBack Then
            For i As Integer = 1 To 5
                Dim tn As New Infragistics.Web.UI.NavigationControls.DataTreeNode()
                tn.Key = "1"
                tn.Value = "N|" & i.ToString()
                tn.Text = "Node" & i.ToString()
                tn.ToolTip = tn.Text
                tn.IsEmptyParent = True
                tn.Expanded = False
                WebDataTree1.Nodes.Add(tn)
            Next
        End If
    End Sub
    Protected Sub WebDataTree1_NodeClick(sender As Object, e As Infragistics.Web.UI.NavigationControls.DataTreeNodeClickEventArgs)
        If e.Node.HasChildren Then
            e.Node.Expanded = Not e.Node.Expanded
            Exit Sub
        End If
        AddNodes(e.Node)
        e.Node.Expanded = True
    End Sub
    Protected Sub WebDataTree1_NodeExpanded(sender As Object, e As Infragistics.Web.UI.NavigationControls.DataTreeNodeEventArgs)
            Exit Sub
        End If
        AddNodes(e.Node)
    End Sub
    Private Sub AddNodes(parentNode As Infragistics.Web.UI.NavigationControls.DataTreeNode)
            tn.Key = CStr(Integer.Parse(parentNode.Key) + 1)
            tn.Value = "N|" & parentNode.Value.Split("|")(1) & i.ToString()
            tn.Text = "Node" & parentNode.Value.Split("|")(1) & i.ToString()
            tn.Expanded = False
            parentNode.Nodes.Add(tn)
        Next
    End Sub
End Class
