I cannot get a DateTimeEditorProvider to properly display just hour:minute in Edit Mode.I added a date/time column to Products table in the Northwind database. I modified the ReadOnly sample and added a date/time column. I added a DateTimeEditorProvider and assigned it to the new date/time column.I need the Edit format to display hours:minutes. However in each of my attempts, it will display the month/day as hour:minute.Here is my code: <form id="form1" runat="server"> <asp:ScriptManager ID="ScriptManager1" runat="server"></asp:ScriptManager> <div> <ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="500px" Width="800px" DataKeyFields="ProductID" DataSourceID="AccessDataSource1" AutoCRUD="false" AutoGenerateColumns="false"> <EditorProviders> <ig:DateTimeEditorProvider ID="WebDateTimeEdit1" runat="server" EditorControl-DisplayModeFormat="{0:g}" EditorControl-EditModeFormat="t"> </ig:DateTimeEditorProvider> </EditorProviders> <Columns> <ig:BoundDataField DataFieldName="ProductID" Key="ProductID" Width="100px" Header-Text="Product ID"></ig:BoundDataField> <ig:BoundDataField DataFieldName="ProductName" Key="ProductName" Width="100px" Header-Text="Product Name"></ig:BoundDataField> <ig:BoundDataField DataFieldName="UnitPrice" Key="UnitPrice" Width="150px" Header-Text="Unit Price"></ig:BoundDataField> <ig:BoundDataField DataFieldName="UnitsInStock" Key="UnitsInStock" Width="100px" Header-Text="Units In Stock"></ig:BoundDataField> <ig:BoundDataField DataFieldName="DiscontinuedDate" Key="DiscontinuedDate" Width="200px" DataFormatString="{0:g}" DataType="System.DateTime" Header-Text="Discontinued Date"> </ig:BoundDataField> </Columns> <Behaviors> <ig:EditingCore> <Behaviors> <ig:CellEditing> <ColumnSettings> <ig:EditingColumnSetting ColumnKey="DiscontinuedDate" EditorID="WebDateTimeEdit1"/> </ColumnSettings> <EditModeActions MouseClick="Single" /> </ig:CellEditing> </Behaviors> </ig:EditingCore> </Behaviors> </ig:WebDataGrid> </div> <asp:AccessDataSource ID="AccessDataSource1" runat="server" DataFile="~/App_Data/Nwind.mdb" SelectCommand="SELECT ProductID, ProductName, UnitPrice, UnitsInStock, DiscontinuedDate FROM [Products] "></asp:AccessDataSource> </form>
anyone have an answer for this issue?
Can anyone from Infragistics explain behavior shown above?
I updated the code to use "HH:mm" and {HH:mm} and the results were the same, as evidenced by the screen shot
Hello Kenneth,
Thank you for your question.
Could you please try the time format "HH:mm", that is pointed here:
http://www.gnu.org/software/pspp/manual/html_node/Time-and-Date-Formats.html
I am using Infragistics4.Web.v14.1, Version=14.1.20141.1015 with IE 8.
