50
Comparing Dates in WebDateChooser
I have a webDateChooser in my aspx page and 2 text boxes below it. When I select a date through the DateChooser drop down, I want to check if the selected date in less than Sep-30-2015. If this condition is met, then the Text box A should be enabled else if the Date is greater than Oct-01-2015 then the Text Box B should be enabled.
I am trying to write the below JavaScript on the AfterCloseUp event (please correct me If I am wrong here).
Any urgent help is much appreciated. Thanks in advance !
function CalendarDateOfServiceNew_AfterCloseUp(oDateChooser, dropDownPanel, oEvent) {
var date = oDateChooser.getValue();
alert(date);
if (date <= '09/30/2015') {
alert('Text Box A Enableed');
document.getElementById('<%=TextBoxA%>').enabled = true;
else {
alert('Text Box B Enableed');
document.getElementById('<%=TextBoxB%>').enabled = true;
