385
Updating model behind ChartGridView
Hi, using the Android Infragistics toolkit, DataChartView. I have a RangeAreaSeries and a LineSeries that are displaying okay, except that as I add elements to the backing model I'm getting a strange horizontal mirroring of the chart. See this pic -- left side is the actual data and the right side is a mirror of the data reversed (minus the timestampy labels).
https://dl.dropboxusercontent.com/u/56947838/temp.png
I don't have much documentation to go on, but what I'm doing is as I add data to the model, I notify each series of the updated element using this call:
mSeries.notifyInsertItem(i, mValues.get(i));
where 'i' is the last index of the added data. For example, if I started with two elements of data and added a 3rd, the effective call would be:
mSeries.notifyInsertItem(2, mValues.get(2));
and mValues.get(2) returns my last row.
Am I notifying the chart/series correctly about the updated data? I'm adding data relatively quickly so I don't want to recalculate the entire chart. If I invalidate everything then the chart displays properly, albeit slowly as the data set increases.
Thanks.
