Hi,There is a cell in a swftable which is getting displayed as a link. I need to click on the link.
I have captured the BandName using
val = obj.GetNaProperty("DisplayLayouts.Bands[1].Columns[2].Header.Caption") and the used obj.OpenLink "19", val,"Applied", Href .... i dont know how to find the Href value.
I also tried obj.SelectCell "19",val
Both the above methods didnt work for me. Can anyone help me on this.
Hi, I used SwfWindow("Setting Color of URL").SwfTable("ultraGrid1").doubleClickCell (r,c)
It worked. I will also check the part of code given by you.
ThanksRavindra
Ravindra,
Did that work for you?
You should be able to do something like this. Let's say you have activated a cell whose column key is "Url" in the fifth row of the grid with this line:
SwfWindow("Setting Color of URL").SwfTable("ultraGrid1").ActivateCell "4", "Url"
Now you can get the URL in that cell like this:
Dim link
link = SwfWindow("Setting Color of URL").SwfTable("ultraGrid1").GetNAProperty("ActiveCell.Text")
Now you can open the link like this:
SwfWindow("Setting Color of URL").SwfTable("ultraGrid1").OpenLink"4", "Url", link, link
Try that and let me know if it works for you.
I am looking into this for you and I will get back to you as soon as I have figured this out.
