15
SQL Server Installation while Setup and Deployment of the Project
Hi Everyone,
I have a problem with Sql server Installation created with Named Instance  in setup and Deployment of the Windows Application. I have done the setup and Deployment using Visual studio Installer.
The Methods I have tried are,
Method-1) I have selected the Prerequisite button in the Setup project Properties and tick  the .Net Framework and SQL Server Express Options and selected the radiobutton "Download  the Prerequesite from the Component Vendor's Website" and Press Apply and OK but when I deploy the project It is not getting the SQL server installed in the machine.
Method-2) Then I tried with Custom Action View of the Setup Project. In the Install tab, I have added the SQL Express(.exe file) and pass the Arguments in the Property window of the SQL File as "Action=Install /IAcceptSQLServerLicenseTerms=True /InstanceId=SW /InstanceName=SW /SECURITYMODE=SQL /SAPWD="1Soft1". But it also shows the error called "Setup Account Privileges failed while running the setup rules" for Sql Server Installation
The Error Message: "The account that is running SQL Server Setup does not have one or all of the following rights: the right to back up files and directories, the right to manage auditing and the security log and the right to debug programs. To continue, use an account with both of these rights." For more information, see msdn.microsoft.com/.../ms813696.aspx, msdn.microsoft.com/.../ms813959.aspx and msdn.microsoft.com/.../ms813847.aspx.
Method-3) I have tried using the Installer class and in that write the code in the Install Method as
public override void Install(System.Collections.IDictionary stateSaver)
            MessageBox.Show("Installing Application...");
RegistryView registryView = RegistryView.Registry64;
                using (RegistryKey hklm = RegistryKey.OpenBaseKey(RegistryHive.LocalMachine, registryView))
                    //RegistryKey instanceKey = hklm.OpenSubKey(@"SOFTWARE\Microsoft\Microsoft SQL Server\Instance Names\SQL", false);
                    RegistryKey instanceKey = hklm.OpenSubKey(@"SOFTWARE\Wow6432Node\Microsoft\Microsoft SQL Server\Instance Names\SQL", false);
                    //if (instanceKey != null)
                    foreach (var InstanceName1 in instanceKey.GetValueNames())
                        //Console.WriteLine(Environment.MachineName + @"\" + instanceName);
                        MessageBox.Show(Environment.MachineName + @"\" + InstanceName1, "Instances Present in the SERVER", MessageBoxButton.OK, MessageBoxImage.Information);
                    string InstanceName = "SW";
                    object o = instanceKey.GetValue(InstanceName);
                    string x = o?.ToString() ?? "";
                    //string x = o==null? "" : o.ToString();
                    if (x == "MSSQL11.SW")
                        MessageBox.Show("SQL Server with the Instance name \"SW\" already installed", "Alert", MessageBoxButton.OK, MessageBoxImage.Warning);
                    else
 ProcessStartInfo startInfo = new ProcessStartInfo"SQLEXPR_x86_ENU.exe"
                        startInfo.Arguments = "/qs /Action=Install /IAcceptSQLServerLicenseTerms=True /InstanceId=SW /InstanceName=SW /SECURITYMODE=SQL /" + BuildCommandLine();
                        //startInfo.Arguments = @"/qs /Action=Install /IAcceptSQLServerLicenseTerms=True /InstanceId=NRI /InstanceName=NRI /SQLSYSADMINACCOUNTS=""NT AUTHORITY\SYSTEM"" /SQLSVCACCOUNT=""NT AUTHORITY\SYSTEM"" /SQLSVCPASSWORD=""1Soft1"" /SAPWD=""1Soft1""";
                        //Process.Start(startInfo);
                        Process p = new Process();
                        p = Process.Start(startInfo);
                        p.WaitForExit();
Then In Custom Action View, I have added the Project Output file of the Application and in the Property Window of the Output file Set Installerclass="true" .When I install this Setup file the same error shows as mentioned in Method-2.
(The Error Message: "The account that is running SQL Server Setup does not have one or all of the following rights: the right to back up files and directories, the right to manage auditing and the security log and the right to debug programs. To continue, use an account with both of these rights." For more information, see msdn.microsoft.com/.../ms813696.aspx, msdn.microsoft.com/.../ms813959.aspx and msdn.microsoft.com/.../ms813847.aspx.)
Please ,Can Anyone help to solve this issue and error and send me the code with Detailed explanation. I want to install the project  like,While running the Setup.msi file, the SQL Server with Named Instance gets installed if it is not present and then open the application with desktop shortcut created for the Project.
Dhivya
using System.Configuration;
using System.Data.SqlClient;
using System.Diagnostics;
using System.IO;
using System.Linq;
using System.Reflection;
using System.Text;
using System.Threading;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using Microsoft.SqlServer.Management.Common;
using Microsoft.SqlServer.Server;
using System.Security.AccessControl;
using System.Security.Principal;
using System.Data;
using System.Collections;
using System;
using Microsoft.Win32;
using System.Collections.Generic;
namespace EntityFramework
    /// <summary>
    /// Interaction logic for MainWindow.xaml
    /// </summary>
    public partial class Window1 : Window
        private bool os64 = true;
        private string setupFolder = "";
        private string filename;
        //Variables for setup.exe command line
        //private string instanceName = "SQLEXPRESS";
        private string instanceid = "";
        private string installSqlDir = "";
        private string installSqlSharedDir = "";
        private string installSqlDataDir = "";
        // private string addLocal = "All";
        private bool sqlAutoStart = true;
        private bool sqlBrowserAutoStart = false;
        private string sqlBrowserAccount = "NT AUTHORITY\\SYSTEM";
        private string sqlBrowserPassword = "";
        private string SQLSYSADMINACCOUNTS = "NT AUTHORITY\\SYSTEM";
        private string SQLSVCACCOUNT = "NT AUTHORITY\\SYSTEM"; //"NT AUTHORITY\\SYSTEM";
        private bool sqlSecurityMode = true;
        private string SQLSVCPASSWORD = "";
        public string SAPWD = "dhivya123";
        private string sqlCollation = "";
        private bool disableNetworkProtocols = true;
        private bool errorReporting = true;
        //private string sqlExpressSetupFileLocation = "C:\\Program Files\\Microsoft SQL Server\\110\\Setup Bootstrap\\SQLServer2012\\setup.exe";
        private bool enableRANU = false;
        //System.Environment.GetEnvironmentVariable("TEMP") +
        #region Properties
        //public string InstanceName
        //    get
        //        return instanceName;
        //    set
        //        instanceName = value;
        public string InstanceID
            get
                return instanceid;
            set
                instanceid = value;
        //public string SetupFileLocation
        //    get
        //        return sqlExpressSetupFileLocation;
        //    set
        //        sqlExpressSetupFileLocation = value;
        public string SqlInstallSharedDirectory
            get
                return installSqlSharedDir;
            set
                installSqlSharedDir = value;
        public string SqlDataDirectory
            get
                return installSqlDataDir;
            set
                installSqlDataDir = value;
        //public bool AutostartSQLService
        //    get
        //        return sqlAutoStart;
        //    set
        //        sqlAutoStart = value;
        //public bool AutostartSQLBrowserService
        //    get
        //        return sqlBrowserAutoStart;
        //    set
        //        sqlBrowserAutoStart = value;
        public string SqlBrowserAccountName
            get
                return sqlBrowserAccount;
            set
                sqlBrowserAccount = value;
        public string SqlBrowserPassword
            get
                return sqlBrowserPassword;
            set
                sqlBrowserPassword = value;
        //Defaults to LocalSystem
        public string SqlServiceAccountName
            get
                return SQLSYSADMINACCOUNTS;
            set
                SQLSYSADMINACCOUNTS = value;
        public string SqlServicePassword
            get
                return SQLSVCACCOUNT;
            set
                SQLSVCACCOUNT = value;
        public string sqlsapassword
            get
                return SAPWD;
            set
                SAPWD = value;
        public bool UseSQLSecurityMode
            get
                return sqlSecurityMode;
            set
                sqlSecurityMode = value;
        public string SysadminPassword
            set
                SQLSVCPASSWORD = value;
        public string Collation
            get
                return sqlCollation;
            set
                sqlCollation = value;
        public bool DisableNetworkProtocols
            get
                return disableNetworkProtocols;
            set
                disableNetworkProtocols = value;
        public bool ReportErrors
            get
                return errorReporting;
            set
                errorReporting = value;
        public string SqlInstallDirectory
            get
                return installSqlDir;
            set
                installSqlDir = value;
        public bool EnableRANU
            get { return enableRANU; }
            set { enableRANU = value; }
        #endregion
        string strConn = ConfigurationManager.ConnectionStrings["EFEntitiesContainer"].ConnectionString;
        EFEntitiesContainer db = new EFEntitiesContainer();
        public Window1()
            try
                InitializeComponent();
                OSCheck_Install();
                //RestartPc();
                ProgramFiles_check();
                Attach_Database();
                AfterRestart_startApp();
            catch (Exception ex)
                MessageBox.Show("A handled exception just occurred: " + ex.Message, "Exception Sample", MessageBoxButton.OK, MessageBoxImage.Stop);
            //RestoreDatabase();
            //BackupDatabase();
            //Emp_DetailViewModel vm = new Emp_DetailViewModel();
            //DataContext = vm;
            //EFEntitiesContainer db = new EFEntitiesContainer();
            //dgrid.ItemsSource = db.Emp_Table.ToList();
        private void RestoreDatabase()
            string s = System.IO.Path.GetPathRoot(Environment.SystemDirectory);
            s += @"Nortech Controls\";
            string mdfLocation = System.IO.Path.GetPathRoot(Environment.SystemDirectory);
            string ldfLocation = System.IO.Path.GetPathRoot(Environment.SystemDirectory);
            mdfLocation += @"Nortech Controls\EmployeeInfo.mdf";
            ldfLocation += @"Nortech Controls\EmployeeInfo_log.ldf";
            string str_back = s + @"Backup\"; //System.IO.Path.Combine(s, "Backup\\EmployeeInfo.bak");//s + @"Backup\";
            SqlConnection conn = new SqlConnection("Data Source=localhost\\NORTECH;User Id=sa;Password=dhivya123;integrated security=True");
            if (!Directory.Exists(str_back))
                Directory.CreateDirectory(str_back);
            string back = System.IO.Path.Combine(str_back, "EmployeeInfo.bak"); //File.Create(System.IO.Path.Combine(str_back, "EmployeeInfo.bak")).ToString();
            System.Diagnostics.Debug.WriteLine(back);
            System.Diagnostics.Debug.WriteLine(str_back);
            conn.Open();
            string str_cmd1 = "USE master; ALTER DATABASE EmployeeInfo SET SINGLE_USER WITH ROLLBACK IMMEDIATE;";
            System.Diagnostics.Debug.WriteLine(str_cmd1);
            SqlCommand cmd = new SqlCommand(str_cmd1, conn);
            cmd.ExecuteNonQuery();
            //string str_cmd2 = @"DROP DATABASE EmployeeInfo";
            //System.Diagnostics.Debug.WriteLine(str_cmd2);
            //SqlCommand cmd2 = new SqlCommand(str_cmd2, conn);
            //cmd2.ExecuteNonQuery();
            string str_cmd = "RESTORE DATABASE EmployeeInfo FROM DISK =" + "'" + back + "'" + " WITH replace ALTER DATABASE EmployeeInfo SET MULTI_USER";
            //string str_cmd = "RESTORE DATABASE EmployeeInfo FROM DISK =" + "'" + str_back + "'"+ " with move 'EmployeeInfo' TO "+"'"+ mdfLocation+"'"+", move 'EmployeeInfo_log' TO "+"'"+ ldfLocation+"'";
            System.Diagnostics.Debug.WriteLine(str_cmd);
            cmd = new SqlCommand(str_cmd, conn);
            conn.Close();
            //MessageBox.Show("Database Restored Successful.");
        //private void restore_db_Click(object sender, RoutedEventArgs e)
        //    string s = System.IO.Path.GetPathRoot(Environment.SystemDirectory);
        //    s += @"Nortech Controls\";
        //    string mdfLocation = System.IO.Path.GetPathRoot(Environment.SystemDirectory);
        //    string ldfLocation = System.IO.Path.GetPathRoot(Environment.SystemDirectory);
        //    mdfLocation += @"Nortech Controls\EmployeeInfo.mdf";
        //    ldfLocation += @"Nortech Controls\EmployeeInfo_log.ldf";
        //    string str_back = s + @"Backup\"; //System.IO.Path.Combine(s, "Backup\\EmployeeInfo.bak");//s + @"Backup\";
        //    SqlConnection conn = new SqlConnection("Data Source=localhost\\NORTECH;User Id=sa;Password=dhivya123;integrated security=True");
        //    if (!Directory.Exists(str_back))
        //        Directory.CreateDirectory(str_back);
        //    string back = System.IO.Path.Combine(str_back, "EmployeeInfo.bak"); //File.Create(System.IO.Path.Combine(str_back, "EmployeeInfo.bak")).ToString();
        //    System.Diagnostics.Debug.WriteLine(back);
        //    System.Diagnostics.Debug.WriteLine(str_back);
        //    conn.Open();
        //    string str_cmd1 = "USE master; ALTER DATABASE EmployeeInfo SET SINGLE_USER WITH ROLLBACK IMMEDIATE";
        //    System.Diagnostics.Debug.WriteLine(str_cmd1);
        //    SqlCommand cmd = new SqlCommand(str_cmd1, conn);
        //    cmd.ExecuteNonQuery();
        //    //string str_cmd2 = @"DROP DATABASE EmployeeInfo";
        //    //System.Diagnostics.Debug.WriteLine(str_cmd2);
        //    //SqlCommand cmd2 = new SqlCommand(str_cmd2, conn);
        //    //cmd2.ExecuteNonQuery();
        //    string str_cmd = "RESTORE DATABASE EmployeeInfo FROM DISK =" + "'" + back + "'" + " WITH replace ALTER DATABASE EmployeeInfo SET MULTI_USER";
        //    //string str_cmd = "RESTORE DATABASE EmployeeInfo FROM DISK =" + "'" + str_back + "'"+ " with move 'EmployeeInfo' TO "+"'"+ mdfLocation+"'"+", move 'EmployeeInfo_log' TO "+"'"+ ldfLocation+"'";
        //    System.Diagnostics.Debug.WriteLine(str_cmd);
        //    cmd = new SqlCommand(str_cmd, conn);
        //    conn.Close();
        //    MessageBox.Show("Database Restored Successful.");
        private void backup_db_Click(object sender, RoutedEventArgs e)
            string str_back = s + @"Backup\";//System.IO.Path.Combine(s, "Backup\\EmployeeInfo.bak");
            conn.Open();
            //string str_cmd = "BACKUP DATABASE EmployeeInfo TO DISK =" + "'" + back + "'";
            string str_cmd = "BACKUP DATABASE EmployeeInfo TO DISK = '" + back + "';";
            SqlCommand cmd = new SqlCommand(str_cmd, conn);
            conn.Close();
            MessageBox.Show("Database Backup Successful.");
        //private void BackupDatabase()
        //    string str_back = s + @"Backup\";//System.IO.Path.Combine(s, "Backup\\EmployeeInfo.bak");
        //    if(!Directory.Exists(str_back))
        //    conn.Open();
        //    //SqlCommand cmd = new SqlCommand();
        //    SqlDataReader reader;
        //    string str_cmd= @"BACKUP DATABASE EmployeeInfo TO DISK =" + "'" + back + "'" + "";
        //    //cmd.CommandText = @"BACKUP DATABASE EmployeeInfo TO DISK ="+ "'"+ back + "'" + "";
        //    SqlCommand cmd = new SqlCommand(str_cmd,conn);
        //    //cmd.CommandType = CommandType.Text;
        //    //cmd.Connection = conn;
        //    //reader = cmd.ExecuteReader();
        //    conn.Close();
        //    MessageBox.Show("Database Backup Successful.");
        //}//str_back+ @"EmployeeInfo.bak"
        private void Attach_Database()
            if (Environment.Is64BitOperatingSystem)
                //string str = Environment.GetEnvironmentVariable(@"ProgramFiles(x86)");
                //str += @"\Microsoft SQL Server\MSSQL11.NORTECH\MSSQL\DATA\";
                string str_db;
                bool result = false;
                //string sqlConnectionString = "Data Source=localhost\\NORTECH;User Id=sa;Password=dhivya123;integrated security=True";
                try
                    //SqlConnection conn = new SqlConnection("Data Source=localhost\\NORTECH;User Id=sa;Password=dhivya123;integrated security=True");
                    string dbase = "EmployeeInfo";
                    str_db = string.Format("SELECT database_id  FROM sys.databases WHERE Name = '{0}'", dbase);
                    using (conn)
                        using (SqlCommand sqlCmd = new SqlCommand(str_db, conn))
                            conn.Open();
                            object resultObj = sqlCmd.ExecuteScalar();
                            int databaseID = 0;
                            if (resultObj != null)
                                int.TryParse(resultObj.ToString(), out databaseID);
                            else
                                if (Directory.Exists(s))
                                    DirectoryInfo dInfo = new DirectoryInfo(s);
                                    DirectorySecurity dSecurity = dInfo.GetAccessControl();
                                    dSecurity.AddAccessRule(new FileSystemAccessRule("everyone", FileSystemRights.FullControl,
        InheritanceFlags.ObjectInherit | InheritanceFlags.ContainerInherit,
        PropagationFlags.NoPropagateInherit, AccessControlType.Allow));
                                    //dSecurity.AddAccessRule(new FileSystemAccessRule(new SecurityIdentifier(WellKnownSidType.WorldSid, null), FileSystemRights.FullControl, InheritanceFlags.ObjectInherit | InheritanceFlags.ContainerInherit, PropagationFlags.NoPropagateInherit, AccessControlType.Allow));
                                    dInfo.SetAccessControl(dSecurity);
                                    DirectoryInfo dInfo1 = new DirectoryInfo(mdfLocation);
                                    DirectorySecurity dSecurity1 = dInfo1.GetAccessControl();
                                    dSecurity1.AddAccessRule(new FileSystemAccessRule("everyone", FileSystemRights.FullControl,
                                    dInfo.SetAccessControl(dSecurity1);
                                    //conn.Open();
                                    str_db = "CREATE DATABASE EmployeeInfo ON " +
                                        //str_db = "CREATE DATABASE" + dbase + "ON " +
                                        "PRIMARY ( FILENAME =" + "'" + mdfLocation + "'" + " ),( FILENAME =" + "'" + ldfLocation + "'" + " ) " +
                                        //"PRIMARY ( FILENAME ='C:\\Program Files (x86)\\Microsoft SQL Server\\MSSQL11.NORTECH\\MSSQL\\DATA\\EmployeeInfo.mdf' ),( FILENAME ='C:\\Program Files (x86)\\Microsoft SQL Server\\MSSQL11.NORTECH\\MSSQL\\DATA\\EmployeeInfo_log.ldf' ) " +
                                        "FOR ATTACH";
                                    System.Diagnostics.Debug.WriteLine(str_db);
                                    SqlCommand cmd = new SqlCommand(str_db, conn);
                                    try
                                        //conn.Open();
                                        MessageBox.Show(ex.Message);
                                    conn.Close();
                                //conn.Close();
                                result = (databaseID > 0);
                    result = false;
                MessageBox.Show("Database Connection Success");
                System.Diagnostics.Debug.WriteLine(result.ToString());
            else
                string str = Environment.GetEnvironmentVariable(@"ProgramFiles");
                string str_db;
                try
                    using (conn)
                            conn.Open();
                            int databaseID = 0;
                            else
                                    //conn.Open();
                                        //"PRIMARY ( FILENAME ='C:\\Program Files\\Microsoft SQL Server\\MSSQL11.NORTECH\\MSSQL\\DATA\\EmployeeInfo.mdf' ),( FILENAME ='C:\\Program Files\\Microsoft SQL Server\\MSSQL11.NORTECH\\MSSQL\\DATA\\EmployeeInfo_log.ldf' ) " +
                                        "FOR ATTACH";
                                    try
                                        //conn.Open();
                                    conn.Close();
                                //conn.Close();
                    result = false;
            //conn.Open();
            //else
            //    string str = Environment.GetEnvironmentVariable(@"ProgramFiles");
            //    str += @"\Microsoft SQL Server\MSSQL11.NORTECH\MSSQL\DATA\";
            //    string str_db;
            //    //string sqlConnectionString = "Data Source=localhost\\NORTECH;User Id=sa;Password=dhivya123;integrated security=True";
            //    //string dbase = "EmployeeInfo";
            //    Boolean bRet = false;  //***Check database exists in sql server or not*****//
            //    if (bRet == true)
            //        MessageBox.Show("Database Exists");
            //    else
            //        if (Directory.Exists(str))
            //            DirectoryInfo dInfo = new DirectoryInfo(str);
            //            DirectorySecurity dSecurity = dInfo.GetAccessControl();
            //            dSecurity.AddAccessRule(new FileSystemAccessRule("everyone", FileSystemRights.FullControl,
            //                                             InheritanceFlags.ObjectInherit | InheritanceFlags.ContainerInherit,
            //                                             PropagationFlags.NoPropagateInherit, AccessControlType.Allow));
            //            //dSecurity.AddAccessRule(new FileSystemAccessRule(new SecurityIdentifier(WellKnownSidType.WorldSid, null), FileSystemRights.FullControl, InheritanceFlags.ObjectInherit | InheritanceFlags.ContainerInherit, PropagationFlags.NoPropagateInherit, AccessControlType.Allow));
            //            dInfo.SetAccessControl(dSecurity);
            //            conn.Open();
            //            str_db = "CREATE DATABASE EmployeeInfo ON " +
            //                //str_db = "CREATE DATABASE" + dbase + "ON " +
            //                "PRIMARY ( FILENAME ='C:\\Program Files\\Microsoft SQL Server\\MSSQL11.NORTECH\\MSSQL\\DATA\\EmployeeInfo.mdf' ),( FILENAME ='C:\\Program Files\\Microsoft SQL Server\\MSSQL11.NORTECH\\MSSQL\\DATA\\EmployeeInfo_log.ldf' ) " +
            //                "FOR ATTACH";
            //            SqlCommand cmd = new SqlCommand(str_db, conn);
            //            try
            //                //conn.Open();
            //            catch (Exception ex)
            //                MessageBox.Show(ex.Message);
            //            conn.Close();
            //    conn.Open();
            //try
            //    //if (!File.Exists(str + @"EmployeeInfo.mdf") || (!File.Exists(str + @"EmployeeInfo_log.ldf")))
            //        conn.Open();
            //        SqlCommand cmd = new SqlCommand("select * from master.dbo.sysdatabases where name ='EmployeeInfo'", conn);
            //        SqlDataReader dr = cmd.ExecuteReader();
            //        bRet = dr.HasRows;
            //        conn.Close();
            //        bRet = false;
            //if (bRet == true)
            //else
            //        conn.Open();
            //            "PRIMARY ( FILENAME ='C:\\Program Files (x86)\\Microsoft SQL Server\\MSSQL11.NORTECH\\MSSQL\\DATA\\EmployeeInfo.mdf' ),( FILENAME ='C:\\Program Files (x86)\\Microsoft SQL Server\\MSSQL11.NORTECH\\MSSQL\\DATA\\EmployeeInfo_log.ldf' ) " +
            //            "FOR ATTACH";
            //        try
            //            //conn.Open();
            //        conn.Close();
            //conn.Open();
            //try
            //        conn.Open();
            //        conn.Close();
            //        bRet = false;
            //    else
            //            conn.Open();
            //                "FOR ATTACH";
            //            try
            //                //conn.Open();
            //            conn.Close();
            //    conn.Open();
        //str_db = "CREATE DATABASE EmployeeInfo ON " +
        //        "FOR ATTACH";
        //    //SqlCommand cmd = new SqlCommand(str_db, conn);
        //    try
        //        //conn.Open();
        //    conn.Close();
        //conn.Open();
        //using (conn = new SqlConnection(sqlConnectionString))
        /**--Script sql file --***/
        //string sqlCommandFilePath = System.IO.Path.Combine(AppDomain.CurrentDomain.BaseDirectory, @"EFEntities.edmx.sql");
        //if (File.Exists(sqlCommandFilePath))
        //    string script = File.ReadAllText(sqlCommandFilePath);
        //    var sqlqueries = script.Split(new[] { " GO " }, StringSplitOptions.RemoveEmptyEntries);
        //    using (SqlCommand command = new SqlCommand(script, conn))
        //    //conn.Open();
        //        foreach (var query in sqlqueries)
        //            command.CommandText = query;
        //            command.ExecuteNonQuery();
        //        //int affectedRows = command.ExecuteNonQuery();
        //conn.Close();
        //SqlConnection conn = new SqlConnection("user id=sa;" +
        //                           "password=dhivya123;server=localhost\\NORTECH;" +
        //                           "Trusted_Connection=yes;" +
        //                           "database=EmployeeInfo; " +
        //                           "connection timeout=30");
        //    string str_db;
        //    SqlConnection conn = new SqlConnection("Server=localhost\\NORTECH;Integrated security=SSPI;database=master");
        //    string str = Environment.GetEnvironmentVariable(@"ProgramFiles(x86)");
        //        str_db = "CREATE DATABASE 'EmployeeInfo' ON PRIMARY " +
        //        "(NAME = EmployeeInfo_Data, " +
        //"FILENAME = 'C:\\Program Files (x86)\\Microsoft SQL Server\\MSSQL11.NORTECH\\MSSQL\\DATA\\EmployeeInfo.mdf', " +
        //"SIZE = 2MB, MAXSIZE = 10MB, FILEGROWTH = 10%) " +
        //"LOG ON (NAME = EmployeeInfo_Log, " +
        //"FILENAME = 'C:\\Program Files (x86)\\Microsoft SQL Server\\MSSQL11.NORTECH\\MSSQL\\DATA\\EmployeeInfo_log.ldf', " +
        //"SIZE = 1MB, " +
        //"MAXSIZE = 5MB, " +
        //"FILEGROWTH = 10%)";
        //        // conn.Open();
        //        try
        //            conn.Open();
        //            cmd.Dispose();
        //            conn.Dispose();
        //        catch (Exception e)
        //            MessageBox.Show(e.ToString());
        //cmd.ExecuteNonQuery();
        //cmd.Dispose();
        //conn.Dispose();
        private void ProgramFiles_check()
            //if (8 == IntPtr.Size
            //|| (!String.IsNullOrEmpty(Environment.GetEnvironmentVariable("PROCESSOR_ARCHITEW6432"))))
                //C:\Program Files (x86)\Microsoft SQL Server\MSSQL11.NORTECH
                string str = System.IO.Path.GetPathRoot(Environment.SystemDirectory);
                str += @"Program Files (x86)\Microsoft SQL Server\MSSQL11.NORTECH\MSSQL\DATA\";
                System.Diagnostics.Debug.WriteLine(str);
                //string file = System.IO.Path.Combine(str, "EmployeeInfo.mdf","EmployeeInfo_log.ldf");
                //System.Diagnostics.Debug.WriteLine(str);
                System.Diagnostics.Debug.WriteLine(s);
                //s += @"DB\EmployeeInfo.mdf";
                if (!Directory.Exists(s))
                    Directory.CreateDirectory(s);
                    string executableLocation = System.IO.Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location);
                    string mdfLocation = System.IO.Path.Combine(executableLocation, "DB\\EmployeeInfo.mdf"); /**** This 'DB\Employee.mdf' is taken from the Application Project-"bin folder"****/
                    string ldfLocation = System.IO.Path.Combine(executableLocation, "DB\\EmployeeInfo_log.ldf");
                    File.Copy(mdfLocation, s + System.IO.Path.GetFileName(mdfLocation));
                    File.Copy(ldfLocation, s + System.IO.Path.GetFileName(ldfLocation));
                    System.Diagnostics.Debug.WriteLine(System.IO.Path.GetFileName(mdfLocation));
                    System.Diagnostics.Debug.WriteLine(s + System.IO.Path.GetFileName(mdfLocation));
                string executableLocation1 = System.IO.Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location);
                string mdfLocation1 = System.IO.Path.Combine(executableLocation1, "DB\\EmployeeInfo.mdf"); /**** This 'DB\Employee.mdf' is taken from the Application Project-"bin folder"****/
                string ldfLocation1 = System.IO.Path.Combine(executableLocation1, "DB\\EmployeeInfo_log.ldf");
                if (!File.Exists(s + System.IO.Path.GetFileName(mdfLocation1)))
                    File.Copy(mdfLocation1, s + System.IO.Path.GetFileName(mdfLocation1));
                    File.Copy(ldfLocation1, s + System.IO.Path.GetFileName(ldfLocation1));
                //if (Directory.Exists(str))
                //    if (!File.Exists(str+@"EmployeeInfo.mdf")||(!File.Exists(str+@"EmployeeInfo_log.ldf")))
                //        File.Copy(@"C:DB\EmployeeInfo.mdf", str + System.IO.Path.GetFileName("EmployeeInfo.mdf"));
                //        File.Copy(@"C:DB\EmployeeInfo_log.ldf", str + System.IO.Path.GetFileName("EmployeeInfo_log.ldf"));
                //    System.Diagnostics.Debug.WriteLine(str);
                //string file = System.IO.Path.Combine(str, "EmployeeInfo.mdf");
                //conn.Dispose();
            else
                //    if (!File.Exists(str + @"EmployeeInfo.mdf") || (!File.Exists(str + @"EmployeeInfo_log.ldf")))
                //    //string file = System.IO.Path.Combine(str, "EmployeeInfo.mdf");
                //    //conn.Dispose();
            Thread.Sleep(5000);
        private void RestartPc()
            Process.Start("shutdown", "/r /t 0");
        private void AfterRestart_startApp()
            DataContext = vm;
        private void OSCheck_Install()
                        string InstanceName = "NORTECH"; //NORTECH
                        if (x == "MSSQL11.NORTECH")
                            MessageBox.Show("SQL Server with the Instance name \"NORTECH\" already installed", "Alert", MessageBoxButton.OK, MessageBoxImage.Warning);
                        else
                            ProcessStartInfo startInfo = new ProcessStartInfo("SQLEXPR_x86_ENU.exe");
                            startInfo.Arguments = "/qs /Action=Install /IAcceptSQLServerLicenseTerms=True /InstanceId=NORTECH /InstanceName=NORTECH /SECURITYMODE=SQL /" + BuildCommandLine();
                            p.WaitForExit();
                            //if (p.HasExited)
                            //    MessageBox.Show("SQL Server with New Instance has been Successfully installed");
                            //Thread.Sleep(100000);
                            MessageBox.Show("SQL Server with New Instance \"NORTECH\" has been Successfully installed", "Success", MessageBoxButton.OK, MessageBoxImage.Asterisk);
                else
                    RegistryView registryView = RegistryView.Registry32;
                        //RegistryKey instanceKey1 = hklm.OpenSubKey(@"SOFTWARE\Wow6432Node\Microsoft\Microsoft SQL Server\Instance Names\SQL", false);
                        else
                            p.WaitForExit();
                            //if (p.HasExited)
                            // Thread.Sleep(100000);
        private string BuildCommandLine()
            StringBuilder strCommandLine = new StringBuilder();
            //if (!String.IsNullOrEmpty(installSqlDir))
            //    strCommandLine.Append("INSTANCENAME=\"").Append(instanceName).Append("\"");
            //    strCommandLine.Append("INSTANCEID=\"").Append(instanceid).Append("\"");
                strCommandLine.Append("INSTALLSQLDIR=\"").Append(installSqlDir).Append("\"");
            if (!String.IsNullOrEmpty(installSqlSharedDir))
                strCommandLine.Append("INSTALLSQLSHAREDDIR=\"").Append(installSqlSharedDir).Append("\"");
            if (!String.IsNullOrEmpty(installSqlDataDir))
                strCommandLine.Append("INSTALLSQLDATADIR=\"").Append(installSqlDataDir).Append("\"");
            //if (!String.IsNullOrEmpty(addLocal))
            //    strCommandLine.Append("ADDLOCAL=\"").Append(addLocal).Append("\"");
            //if (sqlAutoStart)
            //    strCommandLine.Append("SQLAUTOSTART=1");
            //else
            //    strCommandLine.Append("SQLAUTOSTART=0");
            //if (sqlBrowserAutoStart)
            //    strCommandLine.Append("SQLBROWSERAUTOSTART=1");
            //else
            //    strCommandLine.Append("SQLBROWSERAUTOSTART=0");
            //if (!String.IsNullOrEmpty(sqlBrowserAccount))
            //    strCommandLine.Append("SQLBROWSERACCOUNT=\"").Append(sqlBrowserAccount).Append("\"");
            //if (!String.IsNullOrEmpty(sqlBrowserPassword))
            //    strCommandLine.Append("SQLBROWSERPASSWORD=\"").Append(sqlBrowserPassword).Append("\"");
            if (!String.IsNullOrEmpty(SQLSYSADMINACCOUNTS))
                strCommandLine.Append("SQLSYSADMINACCOUNTS=\"").Append(SQLSYSADMINACCOUNTS).Append("\"");
            if (!String.IsNullOrEmpty(SQLSVCACCOUNT))
                strCommandLine.Append(" /SQLSVCACCOUNT=\"").Append(SQLSVCACCOUNT).Append("\"");
            if (sqlSecurityMode == true)
                strCommandLine.Append(" /SECURITYMODE=SQL");
            if (!String.IsNullOrEmpty(SQLSVCPASSWORD))
                strCommandLine.Append(" /SQLSVCPASSWORD=\"").Append(SQLSVCPASSWORD).Append("\"");
            if (!String.IsNullOrEmpty(SAPWD))
                strCommandLine.Append(" /SAPWD=\"").Append(SAPWD).Append("\"");
            if (!String.IsNullOrEmpty(sqlCollation))
                strCommandLine.Append(" /SQLCOLLATION=\"").Append(sqlCollation).Append("\"");
            //if (disableNetworkProtocols == true)
            //    strCommandLine.Append(" /DISABLENETWORKPROTOCOLS=1");
            //else
            //    strCommandLine.Append(" /DISABLENETWORKPROTOCOLS=0");
            if (errorReporting == true)
                strCommandLine.Append(" /ERRORREPORTING=1");
            else
                strCommandLine.Append(" /ERRORREPORTING=0");
            if (enableRANU == true)
                strCommandLine.Append(" /ENABLERANU=1");
            else
                strCommandLine.Append(" /ENABLERANU=0");
            return strCommandLine.ToString();
        private void btn_Delete_Click(object sender, RoutedEventArgs e)
            int emp_id = (dgrid.SelectedItem as Emp_Table).ID;
            Emp_Table emp = (from identity in db.Emp_Table where identity.ID == emp_id select identity).SingleOrDefault();
            db.Emp_Table.Remove(emp);
            db.SaveChanges();
            //var details = db.Emp_Table.ToList();
        private void btn_Update_Click(object sender, RoutedEventArgs e)
            int emp_id1 = (dgrid.SelectedItem as Emp_Table).ID;
            Emp_Table emp = (from identity in db.Emp_Table where identity.ID == emp_id1 select identity).SingleOrDefault();
            emp.FirstName = txt_fname.Text;
            emp.LastName = txt_lname.Text;
            emp.Department = txt_dept.Text;
            emp.Title = txt_title.Text;
            db.Entry(emp).State = System.Data.Entity.EntityState.Modified;
            db.SaveChanges();
            //ClearAll();
        /*---Select the row in datagrid and the values of that row will display in the textboxes-- */
        private void dgrid_SelectionChanged(object sender, SelectionChangedEventArgs e)
            try
                var row_list = GetDataGridRows(dgrid);
                foreach (DataGridRow single_row in row_list)
                    if (single_row.IsSelected == true)
                        //Get your value over here
                        var data = dgrid.SelectedItem;
                        string fname = (dgrid.SelectedCells[1].Column.GetCellContent(data) as TextBlock).Text;
                        txt_fname.Text = fname;
                        string lname = (dgrid.SelectedCells[2].Column.GetCellContent(data) as TextBlock).Text;
                        txt_lname.Text = lname;
                        string dept = (dgrid.SelectedCells[3].Column.GetCellContent(data) as TextBlock).Text;
                        txt_dept.Text = dept;
                        string title = (dgrid.SelectedCells[4].Column.GetCellContent(data) as TextBlock).Text;
                        txt_title.Text = title;
        public IEnumerable<DataGridRow> GetDataGridRows(DataGrid grid)
            var itemsSource = grid.ItemsSource as IEnumerable;
            if (null == itemsSource) yield return null;
            foreach (var item in itemsSource)
                var row = grid.ItemContainerGenerator.ContainerFromItem(item) as DataGridRow;
                if (null != row) yield return row;
        private void ClearAll()
            txt_fname.Text = "";
            txt_lname.Text = "";
            txt_dept.Text = "";
            txt_title.Text = "";
        private void refresh_db_Click(object sender, RoutedEventArgs e)
            CollectionViewSource.GetDefaultView(dgrid.ItemsSource).Refresh();
  • 22852
    Dhivya,
    Your quesiton doesn't have anything to do with Infragistics and you would be better off asking Microsoft or posting this question on StackOverflow.
