Out .Net application(SWF) is developed using infragistics frames. Now we have to automate it using HP UFT 12.02 version tool. But we are facing issues in Identifying swf object. Could you please let me know if any Add-ins to be installed? If yes,
After Installation, Could you please help in following scenarios.
Ex1: Pls create a function to validate Radio button, here we will pass, radiobutton property to identify(letz say Radio button Name or text or index) based on the argument we have passed, function should select appropriate radio button.
Function ValidateRadioButton(Arg)
Call Function ValidateRadioButton(RadiobuttonName or RadiobuttonText or RadiobuttonIndex)
Ex2: Similar Function to select a particular Checkbox.
Ex3: How to select an item from swfObject listbox.
Hi Thiru,
I have asked sales to reach out to you regarding this query.
Hi Mike,
How long we can use the Test Automation Free addon for UFT? If it is licensed, what could be the cost?
Pls confirm.
Thiru
SSE services
Please watch our How-To video for Windows Forms Test Automation with HP UFT: https://www.youtube.com/watch?v=S_dqzs556vo
This video contains plenty of examples that should help you.
I will pass control's Index id or Class or Path name and etc properties.
Can You pls help
Can you please elaborate on how you need to validate the objects? Are you expecting the controls to have a specific value, or do you simply need to identify its type?
Additionally, please note that UFT will not be able to identify our controls as Infragistics objects without our Test Automation addon installed.
