25
SwfObject
Hi all,
Am working on QTP 11.5 and application is .net window Application. We are using ".net window form" Addinn and am new to project. I can see all the standard window objects like(button,radio button, check box) are grouped under SwfObject Class.
E-g: window("").swfobject("swfobject").swfobject("objectname").click ion Object
So now am in a position of creating a new test with same kind of procedure, but i have tried many ways like mapping,virual Object concept. I am not able to create Repository as like previously Present. Can some help me out.
Thanks in Advance
Mathi
  • 18495
    Hello Mathi,
    Thank you for contacting Infragistics.
    If your Application Under Test (AUT) uses Infragistics for Windows Forms, you will need to install our Test Automation for Windows Forms add-in.  You can find more information about this product through the link below.
    http://es.infragistics.com/products/testautomation
    If you already have our Test Automation add-in installed, then you should record against the sample AUTs that are installed in the Public Documents folder (C:\Users\Public\Documents\Infragistics) to see if they record correctly.
    Please let me know if you have any other questions about this.
