In the project using its UltraToolbarsManager control interface uses imitation Office2007 Ribbon interface, I found a problem, maximize the window, if a dialog or other window is ShowDialog () out, waving the main window, do not know how to solve
webdesign
Thinks for your answer.perhaps my problem is not speaked clearly. I mean that the main form will shake a time when a new form or adialog box pops up .
Perhaps I am missing something, it is expected any interaction with the base window should fail if a dialog window was displayed from that window is currently open, that's standard with any windows application. Close the dialog window, and you should be able to continue.
Also perhaps it maybe related to me not following the issue you are having, what did you mean by "waving the main window?"
