275
How do you retrieve and set the value of a Combo Box in Ultragrid using QTP
Good morning,
I have a Ultragrid which has a combo box in it. When I record, the value will work with the SetCellData if it is correct. Some of our values have trailing spaces and some do not. I need to get the combo box from the cell. Then I can process the items to see if the specified value is available. If available I can select the value.
Can you tell me how to get the combo box object so I can work with it?
Brian
