275
Get values from multi column list view
Good morning,
I have a control showing as a SwfListView in our application.  The list has 2 columns.  I can get the item count with the code below and the value of the first column. How do I get the associated value in the 2nd column?
'Build the output sheet to see what we have for values
sheetNameOutputData = "Output Data"
DataTable.AddSheet(sheetNameOutputData)
Set DTOuptputData = DataTable.GetSheet(sheetNameOutputData)
'Create the columns
columnName = "Value"
EmpltyData = ""
EmptyData = DTOuptputData.AddParameter(columnName, "").Name
var_GetItemsCount = SwfWindow("Summit FT Diagnostics").SwfListView("environmentListView").GetItemsCount()
For loopItems = 1 to var_GetItemsCount
 'Set the output row
 DTOuptputData.SetCurrentRow(loopItems)
 strItemValue = SwfWindow("Summit FT Diagnostics").SwfListView("environmentListView").GetItem(loopItems - 1) 'Subtract 1 since index starts with zero
 'Output the data
 DTOuptputData.GetParameter(columnName).Value = strItemValue
Next
'Header in the object show 2 columns
var_GetColumnHeader = SwfWindow("Summit FT Diagnostics").SwfListView("environmentListView").GetColumnHeader(1)
Brian Washburn
  • 7695
    There are two possibilities. You can use GetColumnContent(sColName or iColIndex), which will get you all the values for that particular column.
    Or you can use GetNAProperty(sPropertyPath)
    Something like the following:
    Set ListView = SwfWindow("Form1").SwfListView("ultraListView1")
    msgbox ListView.GetNAProperty("Items[1].SubItems[0].Text")
