7695
Breaking Change caused by QuickTest Professional 10
     As of the release of QuickTest Professional(QTP) 10 a breaking change was introduced that when we called QTP's internal SendKeys method, which is used to send a string of keys to the application under test(AUT), it caused a thread dead lock. This will manifest itself as freezing or locking up of both the UI of the AUT as well as QTP, this is most commonly seen in but not limited to the UltraWinGrid's SetFilter method, SetInvalidDataCell method, and prior to 2007 Volume 3 in its SetCellData method. A complete list of controls and actions effected are listed below.
     We added a work around for this method in our code to avoid this behavior via a service release in TestAdvantage 2008 Volume 2 and forward, and in the release versions of TestAdvantage 2009 Volume 2 and forward.
     For versions of TestAdvantage\NetAdvantage prior to 2008 Volume 2, it is highly recommended to either upgrade your application to 2008 Volume 2 or later, or downgrade your QTP to prior to 10. If neither of these are viable options, then it is recommended that you log a support case with our developer support, and they will try to cater a solution that bests suits your needs based on the controls and actions that most effect your test case scenarios.
WinCalculatorDropDown
    Clear
WinColorPicker
    Clear
WinComboEditor
    Clear
WinCurrencyEditor
    Set
    Clear
WinDateTimeEditor
    Clear
WinFontNameEditor
    Clear
WinNumericEditor
    Set
    Clear
WinTextEditor
    Clear
WinGauge
    Type
GridCellProxy
    SetCellValue
WinGrid
    SetFilter
    SetFilterRowCell
    SetInvalidDataCell
    SetCellData (prior to 7.3)
WinListView
    EditLabel
WinMaskedEdit
    Set
    SetInvalid
WinFormattedTextEditor
    SpellCheck
WinNavigationBar
    SetLocation
WinPrintPreviewControl
    KeyPressed
CalendarCombo
    SetDate
    Clear
DayView
    AppointmentCreate
    SpellCheck
    ClickToAddAppointment
    SpellCheckNewAppointment
MonthViewSingle
    AppointmentEdit
    NoteEdit
    SpellCheck
WeekView
    AppointmentEdit
    NoteEdit
    SpellCheck
ToolbarsManager
    ShortcutKey
    Set*MaskedTool
    Set*TextBoxTool
    Set*ComboTool
    Set*FontTool
Tree
    LabelEdit
    DeleteSelected
    SetInvalidDataCell
