258
How to use GetColumnControl method for SwfTable(Infragistics.Win.UltraWinGrid.UltraGrid)
How to identify the arguments required for the function GetColumnControl
From the help I can find
column
The column path in the following format "[Band Index];[Column Key]"
What values should I give for band index and Column key.
This how the recorder script comes
TableObject.SetCellData "0","CurrencyGuid","43219"
If I use TableObject.GetColumnControl("0;CurrencyGuid") , I am getting th error "Object required: 'GetColumnControl(...)'"
and if I use TableObject.GetColumnControl("1;CurrencyGuid") , I am getting the error,
Key not found
Parameter name: key
How can I know the correct values for the Column Key,
