85
Exception from HRESULT: 0x80040205 Error message for ClickToolbarTool
Configuration--Running QTP 9.5 with TestAdvantage 2006 Volume 3 CLR 1.x.
The application has UltraToolbars in it.  I have code that will select items on the tool bar.
Example:
SwfWindow("PPlus-Main").SwfToolbar("Add_Edit_Toolbar").ClickToolbarTool "Edit","New"
The line above will successfull click the New button on the Add_Edit_Toolbar.
Example:
SwfWindow("PPlus-Main").SwfWindow("Addresses").SwfToolbar("Add_Edit Toolbar").ClickToolbarTool "Edit","New"
This code that should select the New button in the Add_Edit_Toolbar of a spawned child window.
Problem is that the child window action errors with the following exception:
An unexpected exception was raised (Exception from HRESULT: 0x80040205)
Line (19): "SwfWindow("PPlus-Main").SwfWindow("Phones").SwfToolbar("Add_Edit Toolbar").ClickToolbarTool "Edit","New"".
Has anyone encountered this before?
I tried running the same scripts which came with install of TestAdvantage and they too are generating this exception.
