Hello Team,
We are using UFT 12.54 along with TestAutomation_WinForms_HP_20141 (1) for one of our desktop applications which uses infragistics controls along with .NET Framework V4.
UFT is able to identify and perform all operations except for 'Menubar' and 'Right Click' operations. Could you please help us identifying and resolving the issue? I could be connected on 'LALIT.JHA@MOODYS>COM'.
Lalit
Thank you for telling us which control version you are using.
Could you also tell us what control exactly you are testing?
For your reference, here is the list of supported controls and components, the link being already given to you by Micheal: Infragistics Control
Hi Michael,
We are using Infragistic controls version 7.3. Please let me know, if you need additional information.
Hello Lalit
As long as the version of Test Advantage installed matches the volume of Infragistics recording and playback should run as expected. Which Infragistics control are you testing that demonstrates the behavior you describe? Thanks.
Hello Lalit Jha,
Thank you for posing the question to our forum.
This is just a notice that we've moved your question to "Test Automation for Micro Focus UFT: Windows Forms" as it is a more appropriate place for your question.
We are investigating your question and will let you know when we have an update about it.
