1) Type of AUT (application under test): Desktop 2) Technology: .Net, WPF 3) UFT version UFT 12.02 4) UFT Add-Ins used .NET, Web,WPF,12.1 Test advantage CLR4 5) Problem:
QTP is unable of identifying objects;Am currently tring to automate a wpf tree object.
I need to click on the child item of WPF tree node, for that first i need to expand the parent tree but am not able to perform it.
Tried with following codes and we are not able to select either parent or child node
WpfWindow("XX").WpfTreeView("XXX"). Select "XXXX"WpfWindow("XX").WpfTreeView("XXX").Expand ("XXXX")WpfWindow("XX").WpfTreeView("XXX").ExpandAll
Could you please help on this
Hello SRINIVASAN,
Please do not hesitate if you have any other questions on this matter.
Hello SRINIVASAN Ayyaru,
By looking at the code snippet that you have provided, it seems that you are recording over a Microsoft TreeView control. Infragistics Test Automation for HP/UFT for WPF product only supports the recording and replaying over the Infragistics WPF controls.
Please let me know if I have misunderstood you or if you have any other questions.
