I have came across an issue that RFT is unable to detect any object other than window,titilebar. Application is built on smallTalk technology
can Infragistics TestAdvantage help me?
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
Hello ,
Infragistics TestAdavantage was developed as an add-in for TestAtomation for RFT of IBM and QTP/UFT for HP. It is necessary for the test engine to be able to recognize Infragistics Components and to record and replay test against them. So if your application doesn’t use Infragistics components there is no benefit to use Infragistics TestAdavantage. Based on your post it seems that you do not use Infragistics Components in your application, so getting of Infragistics TestAdavantage won’t help you.
