Rational Functional Tester (RFT) failed to recongized infragistics objects. I am able to record the obeject. However while playback RFT not recognized the objects.
I am using 64 bit Application in Windows 7 environment.
I had installed Test advandage 10.3 which match with the NetAdvantage Version.
And I selected the Version Utility from Start menu.
What is the next step I have to proceed.
Hello Michael,
I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
Hi Michael,
Thank you for contacting Infragistics Developer Support.
Which version of RFT and which version of Visual Studio are you using?
Also, please send me the files located at "C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization"
I am looking forward to your reply.
