Hi ,
I am testing an application called Facets built by trizetto Groups which resides on citrix server.I am using Rational functionalTester(RFT) 8.2.1 to test the application.I am able to capture the objects but the playback is really slow it takes more than 8 seconds to select 1 test object.I have tried all kind of regular expression and different object propertys still no luck. I enabled the log and saw following error message
2011-12-15/11:16:43.036, 5320: 2604, WARNING, rational_ft, File: C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization\Color.dll added to custom list2011-12-15/11:16:43.036, 5320: 2604, WARNING, rational_ft, File: C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization\com.ibm.terminal.tester.ft.jar added to custom list2011-12-15/11:16:43.036, 5320: 2604, WARNING, rational_ft, File: C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization\com.ibm.terminal.tester.ft.rftcust added to custom list2011-12-15/11:16:43.051, 5320: 2604, WARNING, rational_ft, File: C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization\customizations.rftcust added to custom list2011-12-15/11:16:43.051, 5320: 2604, WARNING, rational_ft, File: C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization\CustomObjRecProp.rftop added to custom list2011-12-15/11:16:43.051, 5320: 2604, WARNING, rational_ft, File: C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization\CustomObjRecProp_MySAP.rftop added to custom list2011-12-15/11:16:43.051, 5320: 2604, WARNING, rational_ft, Cleaning up MOZILLA_FIVE_HOME2011-12-15/11:16:43.676, 5104:4196, INFORMATION, Native, Invalid Spy Memory reference: Heap#=12 blockId=0x000010f0 uid=0x000000c22011-12-15/11:16:43.676, 5104:4196, INFORMATION, Native, Invalid Spy Memory reference: Heap#=12 blockId=0x00001d80 uid=0x000000d92011-12-15/11:16:43.692, 5104:4196, INFORMATION, Native, Invalid Spy Memory reference: Heap#=12 blockId=0x000010f0 uid=0x000000c22011-12-15/11:16:43.692, 5104:4196, INFORMATION, Native, Invalid Spy Memory reference: Heap#=12 blockId=0x00001d80 uid=0x000000d92011-12-15/11:16:43.785, 5320: 2604, WARNING, FtClassLoader, FtClassLoader cannot find [Trials.Performance]2011-12-15/11:16:43.801, 5320: 2604, WARNING, FtClassLoader, FtClassLoader cannot find [resources.Trials.PerformanceHelper]2011-12-15/11:16:44.301, 5320: 2604, WARNING, testobjectmethodinvoker, while asking DomainsForName, TestContext is now gone!2011-12-15/11:16:44.301, 5320: 2604, WARNING, testobjectmethodinvoker, while asking DomainsForName, TestContext is now gone!2011-12-15/11:16:57.895, 5320: 2604, WARNING, objectmanager, unregisterAll - caught exception: java.lang.NullPointerException2011-12-15/11:16:57.910, 5320: 2604, WARNING, objectmanager, unregisterAll - caught exception: java.lang.NullPointerException2011-12-15/11:16:58.614, 5744: 4732, ERROR, Java2TestDomainImplementation, Error in Applet Helper Initializerjava.lang.NullPointerExceptioncom.rational.test.ft.sys.TestContext$Reference.getProcessId(TestContext.java:2696)com.rational.test.ft.domain.java.Java2TestDomainImplementation$AppletHelperInitializer.run(Java2TestDomainImplementation.java:161)
I was wondering installing TestAdvantage can solve my perfomance issue
I think the slow replay is caused by recognizing the controls on the application. You might want to play with the recognition level and lower it down so it will go faster. Another reason might be the fact that it is running inside Citrix.
I recommend contacting IBM support for information on this as TestAdvantage does not have any control over this.
I hope this was helpful.
Ammar
