649
how can we call a script in another script??
Hi Ammar,
Rekha.
  • 244
    Rekha,
    You should also be aware of this issue with RFT and CallScript with TestAdvantage:
    http://news.infragistics.com/forums/t/17745.aspx
    Depending on your version of RFT (I don't know if their latest release fixed this or not) you'll need to copy Infragistics.RFT.NetTestObjects.v7.1.dll from C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization\ to the bin directory of your RFT project.
  • 6729
    Suggested Answer
    Hi Rekha,
    This can be done using the standard CallScript method which has 3 overloads:
    CallScript("Script2") ' Script Name
    CallScript("Script2", args) ' Script Name, array of arguments
    CallScript("Script2", args, 2) ' Script Name, array of arguments, number of iteration
    Ammar
