How can i get the header name at second level??
I need the header names in second row i.e., Consists, P, G, S.....etc.
Rekha.
If P, G, S are columns then they have to have unique keys. Please check with your developer to see what is P, G, S and if they are columns then what is their key. also what is the key of the first levle columns like "Values for the Consist"
Also you can try to take a verification point. This will include the column header.
Ammar
Hi Ammar,
Basically the P,G, S columns will not be uniquely identified individually ,
each P or G or S column along with the 1st level column name will be unique.
Hi Rekha,
In order to help you on this case I need to know the column key of the column "P", "S", "G" .. etc
Once you get the column key (you can get this information from the developer) you will use GetNAProperty of the grid test object.
