Hello, I have some problems with setup ipad with shareplus to working with TMG. When I test connection I take message "authentication success" (windows auth), I see the folders list, but when I try open any folder I take error: A connection failure occured.
If I open my site on safari is ok.
If I try open the same site with same domain, user/password in FilamenteLite everything working ok.
And one more question: I finally try setup SahrePlus with client certificate. So client certificate authentication is supported in SharePlus ?
Is any documentation how to setup tmg for client certificate ?
Thanks a lot for help, and hello to all in forum.
Hello caroot,
Thank you for posting at IG forums!
This sounds like an alternate paths issue. I have created the case CAS-90443-7QPB9R in order for us to carry on troubleshooting this issue.
Please follow the instructions in this post to enable technical logs. Once technical logs are enabled duplicate the issue, compress the log files in Local Files and attach them here so I can review the logs.
I'm afraid setting up Forefront with client certificates is not documented in our side since it is a server side configuration. I'll look this up and post here my findings.
Looking forward to hearing from you,
I experienced the same as Toof; delete the app and reinstall fixed my problem.
_______________
concrete driveway contractor
Try accessing the folders from a basket random device or another app to see if the problem is caused by SharePlus or if it has something to do with the TMG configuration.
Input is consistently welcome for us, so if it's not too much trouble, go ahead and reach us. Your custom and satisfaction means quite a bit to us and assists us with being the best escort organization Call Girls in Ashok Vihar in by educating us regarding your experience and how we can work on our administration to you. On each female escort's page, there is a structure for you to compose a survey on them about our escort administration.
Get half off on every one of the administrations by our atractive Escort female. Booked from to get exceptionally interesting and colorful call young ladies. Our escorts administration in at 5k to 50k Call girls in Udaipur alongside Free Room. Attractive, curvy, blonde, dark and earthy colored young ladies offering believed escort administration to all significant regions in.
