110
I want to implament ultraweblistbar in my project .
Please give me soluttion it.
i am using .net 2.0
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="Default.aspx.cs" Inherits="WebApplication21._Default" %>
<%@ Register TagPrefix="iglbar" Namespace="Infragistics.WebUI.UltraWebListbar" Assembly="Infragistics.WebUI.UltraWebListbar.v5.3, Version=5.3.20053.50, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
<title></title>
</head>
<body>
<form id="form1" runat="server">
<div>
<iglbar:ultraweblistbar id="wb" runat="server">
</iglbar:ultraweblistbar>
</div>
</form>
</body>
</html>
Server Error in '/' Application.
Input string was not in a correct format.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.FormatException: Input string was not in a correct format.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[FormatException: Input string was not in a correct format.]
   System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) +7476983
   System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) +119
   System.Convert.ToInt32(String value) +63
   Infragistics.WebUI.UltraWebListbar.UltraWebListbar.getRenderer() +521
   Infragistics.WebUI.UltraWebListbar.UltraWebListbar.PreRenderLBar(Object sender, EventArgs e) +49
   System.Web.UI.Control.OnPreRender(EventArgs e) +8776566
   System.Web.UI.Control.PreRenderRecursiveInternal() +80
   System.Web.UI.Control.PreRenderRecursiveInternal() +171
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +842
Version Information: Microsoft .NET Framework Version:2.0.50727.8009; ASP.NET Version:2.0.50727.8008
