I am using Ultra webgrid V11.1 in IE11 browser. I am facing an issue in loading the infragistics script files in some machines alone.
When debugged with F12 developer tools,
1.Working IE11 browser loads ig_WebGrid.js file
2.Non working IE browser it loads as ig_WebGrid_dl.js
Query:
1.For the same code and in same IE11 browser but in different machines, why it is loading differently?
2.In case2 the click events are not working and also the look and feel is lost. Even the background color is not working.
3.What is the difference between ig_WebGrid.js and ig_WebGrid_dl.js? Is it causing the issue or any thing else?
Ahmed.
See if the user has added the site to compatibility mode within one of the browsers, it effects the way Infragistic plugins work in some hard to predict manners
Could you pls suggest some solution ASAP.
