205
How Do I get UltraWebGridExcelExporter - To Export my Grid Footers
I am using the UltraWebGridExcelExporter control to export my grids but the Nice footers I have designed do not come out in the excel spread sheet. Can someon tell me why?
Larry
www.AboutMeadows.com
www.CJSShades.com
  • 2677
    When you say "the Nice footers I have designed", does that mean that you are creating ColumnFooter objects and adding them to the FooterLayout of the grid.  If that is the case, then that would not be supported and would directly relate to the Note at the beginning of the following article which demonstrates how to create your own ColumnHeader objects and add them to the HeaderLayout.
    ColumnHeader/ColumnFooter
    In order to get something like this to work, you will have to create the row yourself in the exporting events.  Here is a quick snippet of what has to be done.  it uses the SummaryRowExported event and adds a new row to the worksheet.  Then, all that you would have to do is place the appropriate footer values in it.
    protected void UltraWebGridExcelExporter1_SummaryRowExported(object sender, Infragistics.WebUI.UltraWebGrid.ExcelExport.SummaryRowExportedEventArgs e)
    foreach (WorksheetCell cell in e.CurrentWorksheet.Rows[e.CurrentRowIndex].Cells)
    e.CurrentWorksheet.Rows[cell.RowIndex + 1].Cells[cell.ColumnIndex].CellFormat.FillPattern =
    FillPatternStyle.Solid;
    e.CurrentWorksheet.Rows[cell.RowIndex + 1].Cells[cell.ColumnIndex].CellFormat.FillPatternForegroundColor = this.UltraWebGrid1.DisplayLayout.FooterStyleDefault.BackColor;
    e.CurrentWorksheet.Rows[cell.RowIndex + 1].Cells[cell.ColumnIndex].Value = "FooterValue";
     I hope this helps.
