This reports are designed with Infragistics 14.1 under ASP.NET 4.5.
This is one of the reports url: http://www.internetmexico.net/ammvepe/2015/webadmon/eventocongreso/administracion/ReporteInfra02.aspx
When the page is rendered in the server it sends to the client a diferent URL, it sends the server computer name not the webserver name, so this make impossible to PRINT o EXPORT the report on the client
How can I make the server sends the webserver name, so the client can download the Reportservice.svc and be able to pirnt o EXPORT the report?
Please help with this problem.
Thanks for your attention
Luis E Jimenez R
I'm just checking up to see if the suggested resolved your issue. If you have any follow-up questions, please let me know.
Thank you for your information !
Your code is fine, however in order to get the Print button rendered you need Adobe Reader Plugin installed and enabled ! As stated at http://help.infragistics.com/Help/Doc/Reporting/2014.2/CLR4.0/html/HTML5_Report_Viewer_Overview.html the Print button is only shown if the plugin is present.
This should fix issues in both Chrome and Safari.
Please let me know if you have further questions on the matter.
Thanks for your support, I really appreciate it.
Well, the situation is like this. As you can see on the following link:
http://www.internetmexico.net/ammvepe/2015/webadmon/eventocongreso/administracion/reporteinfra02.aspx
you are accesing an actual report, that in Internet Explorer looks great, with all the features for EXPORT, PRINT, ZOOM and REFRESH
But on Google Chrome the PRINT option doesn't show up, and if you use SAFARI the PRINT option shows up but when you activate this option, the printing dialog box appear and shows that is going to print the WEB PAGE not the REPORT
This is the code on the aspx page to generate the report
<script src="Scripts/modernizr-latest.js" type="text/javascript"></script>
<link href="Styles/base/jquery.ui.all.css" rel="stylesheet" type="text/css" />
<script src="Scripts/jquery-1.10.2.js" type="text/javascript"></script>
<script src="Scripts/jquery-ui-1.10.4.custom.min.js" type="text/javascript"></script>
<script src="Scripts/infragistics.loader.js" type="text/javascript"></script>
$.ig.loader({
cssPath: 'styles',
scriptPath: 'scripts',
resources: 'igReportViewer',
locale: 'en',
ready: function () {
//Page and resources are already loaded
$("#viewer").igReportViewer({
width: 800,
height: 1000,
renderSettings: {
//definitionUri: 'HTML5ClassLibrary;component/Report1.igr',
definitionUri: 'Reportesammvepe;component/Reporte02.igr',
serviceEndpointUri: "ReportService1.svc/ajaxAddress/"
</script>
I hope this help, but if you need more information about this problema please let me know.
Thanks again for your help.
Regards
Luis Enrique Jimenez
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
I am glad you have managed to resolve your issue. Could you please send some screenshots of what you are seeing in IE/Firefox and Chrome to provide more insight of the issue ? It will be also highly appreciated if you can share the code of the Reporting and also the html rendered in the page.
