So I've got a hierarchically defined data structure and I've got the ColumnLayout setup to display that data structure. From a functionality perspective, it's perfect.
What I've been asked to do is to create some visual separation on the child table. In particular, popping a border and adding a margin onto the child table. I see properties for styling the header of the ChildBand, but I'm not seeing anything that allows me to treat the entire sub-table as a whole ... how would you go about this?
Hi Mike,
If you would like you can add this as a suggestion for future implantation at: http://ideas.infragistics.com/. Additional details on the process could be found below.
Steps to create your idea: 1. Log into the Infragistics Product Ideas site at http://ideas.infragistics.com (creating a new login if needed).2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
The benefits of submitting the product idea yourself include:- Direct communication with our product management team regarding your product idea.- Notifications whenever new information regarding your idea becomes available.
Additional benefits of the Product Idea system include:
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.- Allow you to shape the future of our products by requesting new controls and products altogether.- You and other developers can discuss existing product ideas with members of our Product Management team.
The product ideas site allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
After looking at the effort involved to effectively try to put a 5 pixel margin around the child band, it was determined that it wasn't worth it.
If there were a way to more easily manipulate the band as a whole, it would be a desirable feature.
Hello Mike,
I am just checking if you had a chance to look into this and if you would like any further assistance on the matter.
Hello Mike and thank you for your post!
As you have noticed the ChildBand does not have a visual representation that could be styled so that the whole band is highlighted. All child rows are displayed separately under the corresponding parent and the approach that gets closest to the look and feel that you described, and that I could currently think of, is setting a Style for the CellControl. Then by using a converter properties as background and opacity could be modified. You may want to have a look at the samples Krasimir has attached to the following thread and which illustrates this approach: http://es.infragistics.com/community/forums/t/74043.aspx.
