I am working on web application in which I am using Infragistic grid with radio button. During this I am trying to use method of Grid-row that is setSelected() for selecting radio button, but it is not working with IE10 and give error.
Below are some code from Java script through which got error. This whole process is happening at client side.
tempName is grid name
var objects_Grid = igtbl_getGridById(tempName); -- objects_Grid is grid object
var row;
row_1 = objects_Grid.Rows.getRow(i);
row_1.setSelected(true); -- Here it give me error, look like setSelected() is not working.
Also find some work around like using row._select property but its not working in IE10.
Above one code snippet is used for fetching grid record which is selected through the Radio selection.
Earliest reply will be highly appreciated.
Bhavin Pandya
Hello Bhavin,
Since the classic controls were retired and are present in v11.1 for the last time, it is understandable for those to not work with the browsers released after that.
I can suggest you to upgrade to the new ASP.NET Ajax tool-set:
http://es.infragistics.com/products/aspnet
http://es.infragistics.com/samples/aspnet/
