Hi I am using 2 frames.Upper Frame and Lower Frame.
We have our WebMenu in Upper Frame.Menu also has subMenus.
however when we try to expand our menu,subMenus get hidden behind lower farme.
There is some space between upper and lower farme hence we cannot use TargetFrame property to show submenus.
is there any other way so that menu crossover between 2 Frames without getting hidden.
i have seen following article
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=4860
No it is not a bug, it is just the Infragistics rule : new hotfix - more new bugs
If you think it's a bug then you should report the behavior to Infragistics Developer Support so that it can be addressed.
The problem came up after the latest hotfix (with previous everythink was ok).
Looks like missing "" for igUrl var
P.S. Infragistics 6.3 1085
Here is a knowledgebase article that describes how to do cross-frame Menus:
Devin
