I have a WebAsynchronousRefreshPanel and few controls(Button Controls) within it.
I have few controls outside WARP as well.
Have used WARP in order to prevent refreshing the entire Page.
In case of any errors/Exceptions at the server side, A client side function is invoked to display exception.
Following is the Server side code to invoke client side exception:
ScriptManager.RegisterClientScriptBlock(Page, GetType(), "CLOSE_SCRIPT", "DisplayAlertBox('" + Message + "');", true);
And this is the Client side code to display the Message in form of Alert Box:
alert(arg1);
But there is a problem displaying exception incase of exception from a control inside WAPR.The error/exceptions are not getting displayed on to the Client side.It works fine for controls outside WARP.
As displaying error is a must for any controls.. I dont know how to go about this. The controls needs to be inside WARP at any cost.
Any suggestions would be valuable.
Thanks In Advance.
Ok..thanks for letting me know.
I dont think i can use Update Panel as i am using WARP for a reason.
So the only way to make WebDialogWindow work is to make a call to Client side function from server side which would display the WebDialogWindow. I have tried it out and it works as required.
Nuthan.
Hi Nuthan,
The WARP supports only controls which render all its javascript into HtmlWriter at Render event. That makes all AJAX control incompatible, because they use ScriptManager, which does not have any options to modify its architecture related to javascript output.
So, you can not have WebDialogWindow or any other AJAX control inside of WARP. You should use UpdatePanel.
Thanks..Infragistics.WebUI.Shared.CallBackManager.AddScriptBlock(..) worked fine in my case for invoking client side function.
But i have one more Query. I want to invoke a WebDialogWindow (i.e make a WebDialogWindow visible from a server side which is hidden initially) by a control that is within WARP. Currently its not working fine. Could you please provide me with suggestions.
Thanks again.
Within async postback of WARP or WebTab, you can not use standard Register... methods. To pass script to client you may add to WARP a literal control with your javascript statements use Infragistics.WebUI.Shared.CallBackManager.AddScriptBlock(..) with your scipt. You also may process ClientSideEvents.Error events of WARP.
Note: if there is a global server error while async postback of WARP, then full postback will be triggered. Besides client error processing, you may process those global errors on server using Infragistics.WebUI.Shared.CallBackManager.AddErrorHandler(...)
