The following code works as expected:
<asp:DropDownList ID="DropDownList1" runat="server" AutoPostBack="true"> </asp:DropDownList> <igmisc:WebAsyncRefreshPanel ID="WebAsyncRefreshPanel1" runat="server" Width="100%" RefreshTargetIDs="DropDownList2" TriggerControlIDs="DropDownList1" > <asp:DropDownList ID="DropDownList2" runat="server"> </asp:DropDownList></igmisc:WebAsyncRefreshPanel>
If I wrap that in a WebGroupBox it causes the whole page to postback:
<igmisc:WebGroupBox ID="WebGroupBox4" runat="server" Height="65px" Text="Test" Width="100%" Font-Bold="true" > <Template> <asp:DropDownList ID="DropDownList1" runat="server" AutoPostBack="true"> </asp:DropDownList> <igmisc:WebAsyncRefreshPanel ID="WebAsyncRefreshPanel1" runat="server" Width="100%" RefreshTargetIDs="DropDownList2" TriggerControlIDs="DropDownList1" > <asp:DropDownList ID="DropDownList2" runat="server"> </asp:DropDownList></igmisc:WebAsyncRefreshPanel> </Template> </igmisc:WebGroupBox>
Any ideas?
What your seeing is the result of an interfaced called INamingContainer. This is a marker interface that many .NET controls implement, especially controls that provide a template in which you can place arbitrary server controls. The job of INamingContainer is to help ensure that ASP.NET gives each server control a unique ID when it renders the control. This is important so that ASP.NET can construct a control tree on the server, which requires that every server control have a unique ID.
Of course, having ASP.NET change ID's also presents some challanges (as you well know). T get around your problem, you can use the ClientID property that every ASP.NET control exposes. This property gives you the resolved ID that ASP.NET actually renders in the page. T ouse it, try changing your TriggerControlIDs property to:
TriggerControlIDs="<%= IdOfControl.ClientID %>"
This should set the TriggerControlIDs to the resolved ClientID of your DropDownList.
Devin
BTW, ASP.NET's habit of changing the HTML element ID's is actually a common point of angst for ASP.NET developers. Try googling "ASP.NET mangled ids"
It also seems to be broken if a TriggerControlIDs control is in the WebGroupBox. WebGrouBox renames the control to WebGroupBoxId_IdOfControl_ which apperanlty doesn't rename references to the old name outside of the control.
