I am attempting to replace the WebPanel with the WebExplorerBar control and I found this bit of code:
this.MasterPage.GridPanel.Expanded = false;
Therefore, what is the replacement for the Expanded property in the WebExplorerBar control?
Thanks.
Hello Samir,
You may expand the respective ExporerBarGroup by accessing it and calling the Expanded property like the following: WebExplorerBar1.Groups[0].Expanded=true
If you're binding the WebExplorerBar on the server, then in order to expand the explorer items you may handle ItemBound server-side event and use something similar to: e.ExplorerBarItem.ParentItem.Expanded=true. Attached is a sample with similar scenario for your reference.
Sincerely,
Tsanna
