235
Migrating from UltraWebTree to WebDataTree
I am trying to migrate from the UltraWebTree control to the latest Infragistics WebDataTree control and I have the following code:
protected void BindTree() {
            ClearAll();
            if (this.mTreeList == null) {
                return;
            Node parentNode;
            Node childNode;
            Dictionary<int, Node> parentNodes = new Dictionary<int, Node>(((ICollection<IDataItem>) this.mTreeList).Count);
            foreach (IDataItem item in this.mTreeList) {
                if ((int) item["org_level"] == 1) {
                    parentNode = new Node();
                    parentNode.Text = item["name"].ToString();
                    parentNodes.Add((int) item["orgunit_id"], parentNode);
                    Nodes.Add(parentNode);
                } else {
                    parentNode = parentNodes[(int) item["parent_id"]];
                    childNode = new Node();
                    childNode.Text = item["name"].ToString();
                    parentNode.Nodes.Add(childNode);
                    parentNodes.Add((int) item["orgunit_id"], childNode);
            //this.ExpandAll();
What are the corresponding methods for ClearAll() and Node in the new WebDataTree control?
I found ClearDataItems() and DataTreeNode in the assemblies.  Are these the correct replacements?
Thanks.
  • 15320
    Suggested Answer
    Hello Samir,
    The DataTreeNode is the class that represents a data tree node in WebDataTree and here are all available properties and methods exposed by DataTreeNode class: http://help.infragistics.com/doc/ASPNET/2014.1/CLR4.0/?page=Infragistics4.Web.v14.1~Infragistics.Web.UI.NavigationControls.DataTreeNode_members.html
    There is no "ClearAll" method in the WebDataTree, however you may use something similar to WebDataTree1.Nodes.Clear() if you want to remove the nodes from the tree.
    Please take a look at the above link and you will have a clearer picture about DataTreeNode's members. If you have any further questions, feel free to contact me.
    Sincerely,
    Tsanna
