is there a way to programatically un-link the 4 maps once you already have them synced up?
http://es.infragistics.com/samples/silverlight/geographic-map/#/map-synchronization
Hello Joshua,
Were you able to resolve your issue?
Sincerely,Valerie Developer Support Supervisor - XAMLInfragisticswww.infragistics.com/support
In the sample at the link you sent, notice the SyncManager.SyncSettings areas. The following SyncSettings have a SyncChannel which determines which maps are synced to each other. These SyncSettings can be named and retrieved, which will allow you to change the sync channels and therefore, un-sync the maps.
I have attached a sample application to demonstrate the above.
Sincerely,AndrewDeveloper Support IInfragistics Inc.www.infragistics.com/support
