I use 2014.1 SR 2008
When I move the mouse over the Report View control im MVC only Export, Print, Zoom and refesh buttons is available
the rest of the control is blocked
see attached images
var rangeParameters = [{ Key: "Dato_Fra", Value: new Date(2013, 8, 30) },
{ Key: "Dato_Til", Value: new Date(2013, 9, 7) },
{ Key: "Uge", Value: "40" }];
$(document).ready(function () {
var _Fra = $("#Fra").text();
var _Til = $("#Til").text();
var _Uge = $("#Ugen").text();
var Fra = new Date(_Fra.substring(6), _Fra.substring(3, 5) - 1, _Fra.substring(0, 2));
var Til = new Date(_Til.substring(6), _Til.substring(3, 5) - 1, _Til.substring(0, 2));
rangeParameters[0].Value = Fra;
rangeParameters[1].Value = Til;
rangeParameters[2].Value = _Uge;
$("#viewer").igReportViewer({
renderSettings: {
definitionUri: "/Reports/Teknisk_Liste.igr",
serviceEndpointUri: "/ReportService1.svc/ajaxAddress/"
parameters: rangeParameters,
width: 900,
height: 650,
I found the error
in Jquery-ui ver. 1.9.2 .ui-widget-overlay is position set to absolute
but in 1.11.0 its set to fixed
I use 1.11.0
If I change position in 1.11.0 to absolute it Works as normal
