100
how to get previous value of a cell on updateRow event
Hi friends,
Basically I need the previous value of a cell or cells when I modify a row. Thus I can find the item in my database and then update it.
 Thanks in advance.
Talo
Note: The previous cells value are a part of the primary key.
  • 90
    The RowEventArgs parameter in your event handler has two objects - Row and Data.  Row contains the new details and Data contains the old details.
    Something like UltraGridCell oldValue = ((UltraGridRow) e.Data).Cells.FromKey("Description"); will get you the old cell.
    I'm assuming you're talking about the server-side events here.
  • 8680
    Verified Answer
    If your database table has a primary key, save that in a hidden column and use it to find the record you want.
    If there isn't a primary key, your SELECT statement could return two instances of the value you need, like this:
    SELECT MyColumn, MyColumn AS MyColumnForLookup FROM MyTable
    Then, put the second instance in a hidden column and use it to find the record you need.
