I got error like "A cell value can only be set for cells that are part of an UnboundField" exception when i try to add value to the bound column on InitializeRow Event of the grid.
How to solve this or Is there any other event available to update the value(append some special character).
And also what is the sequence of events will fired when we load the WebDataGrid in 13.2 version?
Thanks & Regards,
Tanya
Hello Tanya,
I am following up to see if the information provided has resolved this matter.
Please let me know if I may be of further assistance with this matter.
Thank you for the update. I instead recommending changing the text instead of the value. For example from the initialize row event you could do the following:
e.Row.Items[1].Text = e.Row.Items[1].Text + "*";
Is this a value you want to change permanently in your database? Or is this something you want to do temporary for display purposes in the grid?
I have one grid with 3 columns, first Column is UnboundCheckBox column and other 2 is String column,
In the string column, i need to add * for the some values based on some conditions, So i will highlight the columns having *. How to achieve that?
I have done some looking into this matter and have a few questions concerning this matter. You say you are trying to append some special character, what is the special character? What is the code you are currently using to try and achieve this behavior?
