I use ver. 14.1 in my project
When I move the mouse over the Report View control im MVC only Export, Print, Zoom and refesh buttons is available
the rest of the control is blocked
var rangeParameters = [{ Key: "Dato_Fra", Value: new Date(2013, 8, 30) },
{ Key: "Dato_Til", Value: new Date(2013, 9, 7) },
{ Key: "Uge", Value: "40" }];
$(document).ready(function () {
var _Fra = $("#Fra").text();
var _Til = $("#Til").text();
var _Uge = $("#Ugen").text();
var Fra = new Date(_Fra.substring(6), _Fra.substring(3, 5) - 1, _Fra.substring(0, 2));
var Til = new Date(_Til.substring(6), _Til.substring(3, 5) - 1, _Til.substring(0, 2));
rangeParameters[0].Value = Fra;
rangeParameters[1].Value = Til;
rangeParameters[2].Value = _Uge;
$("#viewer").igReportViewer({
renderSettings: {
definitionUri: "/Reports/Teknisk_Liste.igr",
serviceEndpointUri: "/ReportService1.svc/ajaxAddress/"
parameters: rangeParameters,
width: 900,
height: 650,
2 week and no reply!!!!!!!!!!!!
Do You call this support?
I have uploaded 3 images to show the problem
Image 1 is when report is loaded
Image 2 is when mouse over
Image 3 is the same report in asp.net webform
I use MVC 5 .net 4.5.1 report service 14.1.2008
the only difference between the two project is in web forms is use the loader is mvc I load the js file my self
Hello Christian Sandoy,
Please note, I have not been able to reproduce this issue in my environment. If you are still encountering this behavior, please update me with the answers to the questions I asked in my previous post.
I am looking forward to hearing from you.
Thank you for posting on our forums. I will be happy to assist you with this issue.
May I ask which version of Infragistics assemblies you are referencing in your application? Also, can you post a screenshot that demonstrates this issue? This will allow me to investigation this issue further.
