140
Ultrawebgrid Footer Error in chrome
I have the below code in my application to set visibility to column footer in ultrawebgrid.
Ultrawebgrid1.DisplayLayout.ColFootersVisibleDefault = ShowMarginInfo.Yes;
This works good in Firefox and IE, but shows null reference error in chrome, Please look into the error and help on this
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
   Infragistics.WebUI.UltraWebGrid.RenderDnLvlHTML.ResolveRowLabelStyle(UltraGridRow row) +3
   Infragistics.WebUI.UltraWebGrid.RenderDnLvlHTML.RenderRowLabelStyleClass(UltraGridRow row) +37
   Infragistics.WebUI.UltraWebGrid.RenderDnLvlHTML.RenderColumnsFooters(RowsCollection rows) +591
   Infragistics.WebUI.UltraWebGrid.RenderDnLvlHTML.RenderTable(RowsCollection rows) +2874
   Infragistics.WebUI.UltraWebGrid.RenderDnLvlHTML.RenderTableFrame() +1450
   Infragistics.WebUI.UltraWebGrid.RenderDHTMLGrid.VisitObjects(HtmlTextWriter output) +1057
   Infragistics.WebUI.UltraWebGrid.GridRendererBase.Render(HtmlTextWriter output) +447
   Infragistics.WebUI.UltraWebGrid.UltraWebGrid.Render(HtmlTextWriter output) +410
   System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +57
   System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100
   System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25
   System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +128
   System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +8
   System.Web.UI.Control.Render(HtmlTextWriter writer) +10
   System.Web.UI.UpdatePanel.RenderChildren(HtmlTextWriter writer) +248
   System.Web.UI.UpdatePanel.Render(HtmlTextWriter writer) +37
   System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +216
   System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) +32
   System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +53
   System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +40
   System.Web.UI.Page.Render(HtmlTextWriter writer) +29
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1386
