80
How to perform setDataMapping() in Bean Code?
I try to build my LineChart completely in the bean code. Caption and legends of the charts appear but no axes, grid lines or data lines.
I guess one important problem is the data mapping, which I don't really know how to perform it in bean's code.
JSF code is only this:
<ig:chart id="chart4" binding="#{myChart.chart}" />
JAVA Bean code is:
private void initChart() {
  if (chart == nullchart = new Chart();
  FacesContext context = FacesContext.getCurrentInstance();
  Application application = context.getApplication();
  MethodBinding dataPointListener1 = application.createMethodBinding(
"#{myChart.processDataPoint}", new Class[ { javax.faces.event.ActionEvent.class });
chart.setDataPointListener(dataPointListener1);
chart.setChartType("Line");
chart.setGroupType("Stack100");
chart.setProjectionType("2D");
chart.setStyle("width: 420; height: 320");
  Caption caption =
new Caption();
  caption.setCaption(
"2D Stack100 Line Chart 1");
caption.setPosition("top");
chart.setCaption(caption);
  Legend legend =
new Legend();
  legend.setPosition(
"right");
  legend.setAutoItems(
true);
chart.setLegend(legend);
  Axis xAxis = new Axis();
  xAxis.setType(AxisType.
X.toString());
xAxis.setAutoRange(true);
  xAxis.setAutoRangeSnap(
false);
  xAxis.setAutoTickMarks(
true);
  xAxis.setAutoGridLines(
true);
chart.getChildren().add(xAxis);
  xAxis.setParent(
chart);
  Axis yAxis =
new Axis();
  yAxis.setType(
"y");
  yAxis.setAutoRange(
true);
yAxis.setAutoRangeSnap(true);
  yAxis.setAutoTickMarks(
true);
  yAxis.setAutoGridLines(
true);
chart.getChildren().add(yAxis);
  yAxis.setParent(
chart);
for (int i = 0; i < 3; ++i) {
    Series series =
new Series();
    series.setChartType(ChartType.
LINE.toString());
    NumbersSource data = new NumbersSource();
    ScalarDataModel model =
new ScalarDataModel();
    model.setWrappedData(data.getSparse0());
    series.setDataSource(model);
// series.setDataMapping( "value: column0" );
   chart.getChildren().add(series);
chart.dataBind(context);
- If I activate the line with series.setDataMapping I get the follwing error:
>> WARN Coercions:513 - Ausnahmefehler beim Versuch, String "column0" in Typ "java.lang.Integer" zu konvertieren
>> ERROR ArraySuffix:181 - Dem Operator "." wurde ein Indexwert vom Typ "java.lang.String" zur Anwendung auf eine Liste oder einen Array
>> übergeben; der Wert konnte jedoch nicht in eine ganze Zahl konvertiert werden.
>>17:49:47,593 DEBUG ValueBindingImpl:188 - getValue Evaluation threw exception:
javax.faces.el.ReferenceSyntaxException: Dem Operator "." wurde ein Indexwert vom Typ "java.lang.String" zur Anwendung auf eine Liste oder
>> einen Array übergeben; der Wert konnte jedoch nicht in eine ganze Zahl konvertiert werden.
at com.sun.faces.el.impl.ArraySuffix.evaluate(ArraySuffix.java:183)
The code of the original trial (LineChart) is:
<ig:series markerBulletVisible="true" legendCaption="#{webchart_numbersSource.name1}"
   dataMapping="value: column0; tooltipCaption: caption" dataSource="#{webchart_numbersSource.sparse1}" />
<ig:series markerBulletVisible="true" legendCaption="#{webchart_numbersSource.name2}"
dataMapping="value: column0; tooltipCaption: caption" dataSource="#{webchart_numbersSource.sparse2}" />
So my questions are:
- Does anybody know if the missing data mapping is the problem, that no data and axes is displayed?
- How can I set a valid DataMapping in above listed code?
Best regards, Andrea
  • 1045
    Hi Andrea,
    Instead of using a ScalarDataModel, you should use a ListDataModel.
    Series series = new Series();
    series.setChartType(ChartType.LINE.toString());
    ListDataModel model = new ListDataModel();
    "value: column0" );
    Pamela Brasil
    Technical Documentation Specialist.
