Hi
How do I clear the report viewer (using Silverlight but would be the same for all?) after having generated a report and I want run another?
So for example I fetch my data and render a report. Now my user selects a different report to run, I need the report viewer to clear itself while I wait for my data and the new report to render.
Even I get confused when I look away after selecting my report to run and then looking back I'm not sure if the report has rendered until I see the spinning arrows.
Robin
Hi Robin,
Thank you for your feedaback. I am glad that you have managed to resolve your issue.
Hi Yanko
Works perfectly - exactly what I needed.
Hello Robin,
Thank you for your reply. I have been looking into your requirement and you may set the ‘DefinitionUri’ of the rendering setting of the XamReportViewer to ‘null’ like :
(this.xamReportViewer1.RenderSettings as ClientRenderSettings).DefinitionUri = null;
Let me know, if you need any further assistance on this matter.
I don't think a sample will explain what I require. All I need is a way to clear the ReportViewer control after I have shown a report.
Something like:-
MyReportViewer.Clear();
Kr
Thank you your reply. Could you please, if possible, attach a sample application that shows your scenario in order to investigate it on my side ?
