175
WebTextEditor only keeps one character after erasing
I'm using a WebDataGrid that display customers information.
In order to filter customers, I have added a WebTextEditor, above the grid, with a value into the NullText property.
When I type a text into the TextEditor, it works well and filter my customers. Then, if I keep down the backspace key and type again a word, characters only appear one by one; the first is replaced by the second, the second by the third etc...
Here's my code:
<div >
    <ig:WebTextEditor ID="Txt_Rec" runat="server" NullText="Recherche..." Font-Size="12pt" Height="25px" >
        <ClientEvents KeyUp="Filter" />
    </ig:WebTextEditor>
</div>
<div>
    <ig:WebDataGrid ID="Gri_Clt" runat="server" AutoGenerateColumns="False" Height="400" Width="100%">
        <Columns>
        </Columns>
        <Behaviors>
            <ig:Filtering Visibility="Hidden"></ig:Filtering>
                <ig:Selection CellClickAction="Row" RowSelectType="Single">
                    <SelectionClientEvents RowSelectionChanged="Gri_Clt_SelectionChanged" />
                </ig:Selection>
                <ig:Sorting AscendingImageAltText="Ascendant" DescendingImageAltText="Descendant"></ig:Sorting>
        </Behaviors>
    </ig:WebDataGrid>
</div>
And my filter function :
function Filter() {
    // met les boutons à disabled
    var z_Mod = $get("Cmd_Mod");
    var z_Sup = $get("Cmd_Sup");
    z_Mod.disabled = true;
    z_Sup.disabled = true;
    var grid = $find("Gri_Clt");
    var searchTextBox = $get("Txt_Rec");
    var filtering = grid.get_behaviors().get_filtering();
    // Set up column filter for country name column
    var columnFilter = filtering.get_columnFilterFromKey("NomClt");
    var colFilterExists = (columnFilter ? true : false);
    if (!colFilterExists) {
        columnFilter = filtering.create_columnFilter("NomClt");
    columnFilter.get_condition().set_rule($IG.TextFilterRules.Contains);
    columnFilter.get_condition().set_value(searchTextBox.value);
        filtering.add_columnFilter(columnFilter);
    else {
        filtering.applyFilters();
Best regards,
TL
