Hi, I would like to clear all the authentication values from "Access control" after a successful login, how can I do?
Hi Alessio,
I'm not sure why you want to clear the access-token objects (I suppose you mean that by "authentication values") after it is created as the idea of using access control model is to control the access resources based on this values.
I suggest you to look at the msdn help about the access control model. If you don't find what you need, you could ask in their forum with detailed information what data exactly you need to clear and why this is necessary and they will give you more accurate advice as they support this functionality.
Petia
Infragistics, Inc.
www.infragistics.com/support
