310
Nullable DateTime field causing problems in designer
Hi there
I have a datasource containing a DateTime? field. I added the datasource to the report. Up to this point, everything is perfect. Now, I want to display the field in a TextBox on the report. Actually, it allowed me to set the TextBox to =Fields.Value once. But now, it displays a validation error.
In addition, it doesn't seem possible to set the TextBox to =Field.Value.ToShortDateString() or something similar.
Is there a possibility to use DateTime? and let it format in the TextBox as "dd.MM.yyyy" resp. ToShortDateString() instead of doing that already in the datasource item where I could set the value to string?
